20 Most Recent Baumatic B180SS And B60SS (Bundle) Electric Single Oven Questions & Answers
2answers
Recently moved into a new house and the oven's
First, call a master who understands ovens. Maybe he can fix it. You should not try to repair it yourself, as it is likely to make it worse. If this does not help, then it will be easier to buy a new oven already. In this way, many problems can be avoided. To be honest, I have never encountered problems with household appliances after moving to new homes. I usually use services that provide a full home inspection before buying it. https://www.thinspect.com.au/ is a good example. I hope you can solve your problem. But still, I highly recommend that you just buy a new oven, so you can save a lot of time.
8/19/2020 8:05:30 AM • Baumatic B180SS... • Answered on Aug 19, 2020
Inner glass has fallen out
Have an appliance repairman check if the oven is still under warranty and if any recalls on the door are in force.
12/17/2017 12:55:13 AM • Baumatic B180SS... • Answered on Dec 17, 2017
My b180ss oven will not come on.the fan and light are ok.
I would definately say that the oven element needs replacing.
You will find this located at ther rear of the the oven compartment behind a removeable cover.
4/6/2010 7:22:59 AM • Baumatic B180SS... • Answered on Apr 06, 2010
Thermostat light is on all the time
Themostat is at fault and should be changed.. protect your new element
12/22/2009 9:09:17 AM • Baumatic B180SS... • Answered on Dec 22, 2009
Baumatic b180 oven
The oven cabinet is likely built for several different models, which means that the case could have been built with an extra hole or two that aren't used on your model. This a normal manufacturing technique for mass-product factories. I see from the Baumatic website that several of their models do use a meat thermometer probe, but even if you bought a probe you couldn't use it your oven. Your model doesn't have the correct circuit board and control panel that the oven needs to use the probe. In any case, if you need to order parts from the manufacturer or would like a downloadable Owners Manual for your model, they are available at this website link: http://www.baumatic.co.uk/products/discontinued-models/builtinovens/B185SS-B Hope that helps! ;)
12/20/2009 11:27:41 PM • Baumatic B180SS... • Answered on Dec 20, 2009
No heat in oven
the element may be open circuit, test it by a continuity test. the actual element is inside the metal outer surrounded by a ceramic compound -you will not be able to see any breaks hence the electrical test.
3/3/2009 10:25:30 AM • Baumatic B180SS... • Answered on Mar 03, 2009
Baumatic B180ss Electric oven problem
It sounds like the overheat safety stat is cutting the oven off.
This is prevent the oven overheating and catching fire.
They can go faulty and operate prematurely, causing the prob u are experiencing.
If it is built in , make sure it has adequate ventilation, as this can cause the prob.
Also check to see if it has an external cooling fan fitted, these can fail, and again cause the prob.
They are usually fitted under the top cover of the oven, and designed to keep the oven cool.
It should come on shortly after turning the oven on
These things are the most likely cause of the prob.
plz rate my solution.
Thanks.
12/31/2008 12:03:00 PM • Baumatic B180SS... • Answered on Dec 31, 2008
Baumatic BT2750SS Cooker. Main oven in conventional mode only heats up to 110 and fan comes on when it shouldn't. The fan mode doesn't work?
Check the elements for continuity. Some ovens will do strange things if one element fails due to shared returns. https://www.google.com/search?q=baumatic+bt2750ss+checking+element ..
5/14/2023 4:50:43 PM • Baumatic Ovens • Answered on May 14, 2023
2answers
BAUMATIC OVENS BO7C wiring schematics
Hi, the fastest way to get access to the manual would be to call the company and ask them to email it to you. Then you can print it out on your end if you wish. Thank you.
12/10/2022 11:53:32 PM • Baumatic Ovens • Answered on Dec 10, 2022
Baumatic single oven door won't open fully?
this is usually the door not in place correctly or a broke ndoor hindge
2/2/2019 9:45:07 PM • Baumatic Ovens • Answered on Feb 02, 2019
My baumatic oven Bo7C is off BUT it sounds as if it's still on
Does this happen after you have used the oven and switched it off?
Some ovens have an overrun on the fans to cool them down quickly and should stop after a few minutes.
If this is not the case, it will need investigating further
11/17/2018 10:59:39 PM • Baumatic Ovens • Answered on Nov 17, 2018
Need instructions how to operate oven baumatic 46cm multi function oven ba04636p if possible written instructions please
Here's the operation manual: http://www.mychoice.co.uk/media/handbook/Baumatic/BO460SS.pdf
9/26/2018 12:11:27 AM • Baumatic Ovens • Answered on Sep 26, 2018
WOULD you please have a manual for the Baumatic wall oven model BO65MS.I have moved into a house with no manual. Hoping you can help please
I searched using https://www.google.com but did not find an exact match for the model oven your provided. Although the following free manual has a similar model number, but is not exactly the same, it also has phone numbers and contact information for you to request a manual directly from the manufacturer. https://theelectricdiscounter.blob.core.windows.net/images/kitchen/cooking-appliance/baumatic/bs65ms/bs65ms_manual.pdf https://theelectricdiscounter.blob.core.windows.net/images/kitchen/cooking-appliance/baumatic/bs65ms/bs65ms_manual.pdf
7/25/2018 11:59:05 PM • Baumatic Ovens • Answered on Jul 25, 2018
Baumatic B180SS And B60SS (Bundle) Electric Single Oven Logo
16 questions posted
Top Baumatic Ovens Experts
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
How-2-Repair.com
How-2-Repair.com
Are you a Baumatic Oven Expert? Answer questions, earn points and help others
View Most Popular
Baumatic Ovens
  • Baumatic Ovens
Most Popular Question
thermostat light all time
  • Ovens
