20 Most Recent
Baumatic B604SS Stainless Steel Gas Single Oven Questions & Answers
Hi, I only just installed Baumatic single built in
Hello- This is a brand new model, but it works the same as the rest. Heat is produced by the elements. The fan has an element that glows when heating the air. --Convection oven glass gets hotter than normal fanless models.-- This is all normal operation of the oven. To ensure full life of oven, avoid using the 'self-clean' feature. Techs call this the 'self-destruct' cycle. Please reply to this post if info is helpful- have more if needed- Thanks- Ed
Gas ove will not stay lighting
Hi there you need to change the ffd on your oven
FFd stands for flame faliure device. its like an temperature controlled switch. it is located in the oven and this device is what lets the gas go through once it has reached a certain temp.
It must only be done by a corgi qualified engineer and to be honest your loooking at about 100 pounds.
BAUMATIC OVENS BO7C wiring schematics
the fastest way to get access to the manual would be to call the company and ask them to email it to you. Then you can print it out on your end if you wish.
Thank you.
