20 Most Recent
Dell PowerEdge 700 Server Questions & Answers
Poweredge 700 will not recognized memory
Unless only one 256-MB memory module is
installed, the modules must be installed in identical pairs. If you want
512MB total, you will need to populate by using two identical 256MB
modules or use the same technique for larger memory sticks. That model supports up to 4GB ram of the following type; PC3200 ECC DDR SDRAM DIMMs
I have a Dell power edge 700 server. I came in
This usually means there is a problem with your keyboard connection at the mainboard end. If you keep getting this error and you can not use your input devices, you will need to replace the board.
Good Luck
C2Solutions
Constant beep on poweredge 840 appears to work alright
Hi
Besides standard beeps codes indicating Processor, CPU, Memory or Systemboard failures,
Dell PERC (PowerEdge Expandable Raid Controller) or SAS Controllers (Serial Attached SCSI) generate beeps to alert failures on the RAID sub-system.
From your description of the issues (when the beeps start), i suggest you check PERC or SAS setup. If you have Dell OpenManage Server Administrator installed, you can log-in and check for more information. Additionally, on the next reboot check the PERC/SAS/CERC boot up for any messages. You may also access the PERC (Ctrl+M), SAS (Ctrl+R) CERC (Ctrl+A) Management Menu for specific failures and attempt a rebuild (assuming you have a redundant RAID Volume).
You can also speak with Dell Support and raise a warranty call if the system has warranty.
Note: PowerEdge 840 would ship with PERC or SAS Controller. PowerEdge 700 will ship with PERC or CERC.
Mike
Power is 2950 i912 sel full
Namrata_stha,
The I912 error is referring to the System Event Log is full of events and because of this is unable to log anymore. You must clear the log in order for the Server Management controller to log any more events. Now depending on the OS installed there are different ways to clear it. If Windows Server 2k8 you would use this command - wevtutil el ' foreach { wevtutil cl $_ }
Where with Server 2003 you can go tot he Event viewer and clear it.
Let me know if this helps.
STRIKE f1 ERROR
Please be more specific. You haven't actually asked a question. What are you trying to do? What happens that you aren't expecting?
Format disk
what is your server model? in most cases you can use the operating disc to format the server drives
Serial number CDB6HJ1
Go to start menu. click on 'control panel'. Select 'system and security". Then select 'system'. This should give you the info.
