20 Most Recent
Fujitsu LifeBook E7010 Notebook Questions & Answers
I have a fujitsu siemens
This may cause by an electrical charge in the motherboard itself,Im not really sure how it affects the display of the computer.There's also a possibility that the problem is with the LCD cable or the LCD itself. Please follow this method since it usually fix such problem like that,
1.Removed the battery then unplugged the AC adapter
2.Press and hold the power button or the ON/OFF button for at least 30 seconds
3.Connect the power supply back to your computer then turn it back on.
4. Check if you will see any difference.
5. If nothing happens, try to press and hold Fn and F2 on the keyboard.
If nothing happens, there is a possibility that the problem is with the LCD or monitor itself, maybe it will need a replacement...
I hope this information will be helpful. Thank you for using FixYa...
When I switch on power, system will ON but black screen
At boot up press F2 and enter the BIOS. Here from the first Menu see if the HDD is being read as that seems to be the problem that you are facing. The control is not reading the HDD and hence it does not go beyond the Fujitsu Logo. If the HDD is being read then probably the Windows has gone corrupt and would need re installation.
If HDD is not being read then you must show it to a professional.
Start upis slow and speed
Follow these all tips :
1. Plz remove unwanted Software
2. Install good Licensed Antivirus and scan whole computer
3. Try it Start > Run > type msconfig > enter > in startup option plz uncheck few programmes.
4. Click on My Computer > C: drive > properties > clean disk > OK
Hoping these tips will help you
ENJOY!!!!
Please i use a fujitsu laptop E lifebook. When i
I have to tell you that 1 long beep followed by 2 short beeps are generated from bios for vga errors... This means that you have to get your laptor at the technician as sooner as posible in order to check the vga part of the motherboard for ventilation problems (that's the best solution for you) or for motherboard replacement (I don't think that this solution is very comfortable, since it will cost as a new laptop)
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
I have a Fujitsu Siemens Lifebook E7010, and
check for updates on fujitsu web.. it seems you have to flash the bios.. (when it beeps in most cases there is hardware problem... proc, ram, hard drive, or even mother board... check with manufacture if he had post some of the new updates for your laptop
LIFEBOOK E7010
3 beeps is generally a video card problem. Unsure if your laptop has separate video or if it is imbedded on the board, first make sure ram is fully seated in socket
My fujitsu lifebook e7010 doesnt always turn on properly
If an external monitor is plugged in an the display is ok then the problem is probably an inverter board or bad/loose flex cable to the lcd screen.
If the external display is distorted then the problem is the video adapter on the laptop.
Need help
your problem could be that the hard drive is broken, perhaps with some tool to repair hard disks the problem. test starting for example hiren boot from a memory or cd and see if it recognizes the hdd, if so you can pass some repair tool
How can i reset bios code ?
remove the bios password by removing the
cmos battery, removing the jumper from the pins right next to the battery, marked something like pswd, plugging it in and hitting the start button.Before you open the
case, unplug, remove the bettery, then hold the start button to get rid of any energy.
Keyboard
Sounds like liquid may have been spilled on the keyboard.
Plug in an external usb keyboard and check if it works.
If so, you will need to buy a replacement keyboard and swap it out, best cheap from Ebay.
