20 Most Recent
Fujitsu LifeBook AH530 NoteBook Questions & Answers
I want to completly remove Windows and repl,ace it with Win XP Pro
If you have a valid copy of xp pro, then just insert the disk and boot from it when asked. when you are asked about an install, choose a clean or new install and everything will be erased and you will start over. Be advised that you will need to get the lifebook drivers burned to a disk before you start.
I forget BIOS password for my fujitsu lifebook a
1. Turn off the laptop2. Remove the power cord3. Remove the battery4. Dismantle back screws and pop open the cover.5. Locate the Dry cell (Button Cell)6. Remove the button cell from the laptop.7. Wait for 10 Seconds8. Put back the button cell.9. Fix the back cover by re-screwing10. Put back your laptop battery11. Turn on the laptop12. Thats it !
Some keys are not working on Starup (Random)
Your problem seems to be from the keyboard. Even if it looks good if the keyboard tape is out of whack or some key is no longer working, it can happen that you say, so I change the keyboard.
MY fujitsu lifebook ah530 keeps
Your display setting does not match.You need to setting the display right way.Or you uninstall and install the VGA (graphics)driver again,and simply restart the PC.
Hope it will solve your problem .
Built in microphone not working
1. Ensure the most recent hardware driver for your operating system.
2. Enable device through control panel, bios menu during system start up, and combination of function keys.
3. Do not have external mic connected.
Where is the inverter for fujitsu lifebook ah530
lcd inverter are commonly found at the bottom of the LCD screen after you'd remove the edges cover. try to remove the VGA cable from the laptop and see if the screen will blink or flash.
thanks
