Yes.
The Power Supply has a weak voltage power rail.
1) If ALL of the LED lights were on at once they would use less than 1 Watt of power.
(Amperes, {Amp's} times Voltage = Watts)
2) EACH fan uses 2 to 3 Watts of power.
3) A typical Processor may use 51 to 125 Watts of power. Just depends on what Processor it is.
A) Yellow light is a Diagnostic light. Blinking yellow tells you the Power Supply is bad.
B) When you unplug the 24-pin ATX main power cable from the motherboard, you have relieved the Power Supply of a load, temporarily.
The power supply then builds up enough power, that when you plug the 24-pin ATX main power cable back in, the fans run long enough until the built up power is drained.
How?
Inside the Power Supply are Electrolytic Capacitors.
They are used as Filters.
They filter the incoming AC electricity, and the outgoing DC electricity.
(They are in the Input Stage, and the Output Stage,
1)
http://en.wikipedia.org/wiki/File:PSU-Open1.jpg2)
http://en.wikipedia.org/wiki/Switched-mode_power_supplyClick on the photo at the top right, to enlarge.
The first link above shows a side view.
The second link shows a top view.
The round objects that have a B on them are Electrolytic Capacitors.
They are in the Input Stage.
The ones to the right that surround the letter E, are also Electrolytic Capacitors, and they are in the Output Stage.
Basic construction of an Electrolytic Capacitor used in your power supply, is an aluminum shell case, three strips with a lead off of each one, (Wire), a cap at the top, a cap at the bottom, and Electrolytic Paste.
A) Three Strips:
1) One strip is a metal foil strip with the Positive lead attached to it.
It is the Conducting Strip.
2) One strip is a metal foil strip, and has a Non-Conducting medium applied to it.
It has the Negative lead attached to it.
It is the Non-Conducting Strip.
3) The last strip is a paper composite, and is soaked with Electrolytic Paste.
The case is a cylindrical aluminum shell.
At the top there is a flat, round aluminum disk. It has a K or X shape etched partway into it.
At the bottom is a round, flat synthetic rubber disk. It is the Bung.
The paper-like strip is laid in-between the two metal strips, and all three are rolled up tightly.
The two leads from the Conducting strip, ( + ), and the Non-Conducting strip ( - ) are inserted through the rubber bung at the bottom of the capacitor.
As an Electrolytic Capacitor fails it builds up gas inside. (Hydrogen Gas)
{Gas is created from the Electrolytic Paste }
The gas expands, and begins to push Electrolytic Paste out.
So much paste loss, and the capacitor operates, but at a weakened state.
Too much paste loss, and the capacitor fails.
This is why the computer may have turned on one time, and not the next. Then it fails to turn on at all because of a bad power supply.
This is NOT an invite to open your Power Supply, and attempt to repair it.
Those large capacitors shown in B, (Input Stage) may still be good.
Usual voltage ceiling for them is around 100 VOLTS!
If your fingers touch the two terminals on the bottom of a capacitor, (Radial Aluminum Electrolytic Capacitor), the stored power can be released to YOU!
If your fingers, or any of the rest of your hand, complete a circuit that any of the capacitors are in, the stored power can be released to YOU!
Shock can be from BAD to FATAL.
See if there is an unused computer with a good, compatible power supply, that you can borrow for a test unit.
Also make sure your computer is clean inside.
Dust, dirt, hair, food crumbs, spider webs, etc., will 'Kill' a Power Supply, and a computer F-A-S-T!
{It's just an ATX power supply. The type used in a LOT of desktop personal computers.
If you need a recommendation for a PSU, just hit me up in a Comment}
For additional questions please post in a Comment.
Regards,
joecoolvette
