20 Most Recent HP ProCurve 2524 24x10/100 Mbps Networking Switch Questions & Answers
0answers
Trying to Configure HP ProCurve 2524 24x10/100
This switch will not function as a DHCP server itself. You will need to have a DHCP server on the VLAN with the access points to give out IP's to the wireless users.
HP has free design and configuration services http://www.procurve.com/customercare/services/design-center/index.htm
4/14/2010 9:08:00 PM • HP ProCurve 2524... • Answered on Apr 14, 2010
What does Alignment Rx error mean, when does it
Half/Full Duplex mismatch.
Bad cable, too long a cable
Bad network card in device
The occational error is not a problem. Constant errors on the same port indicate a problem with the cable or device on that port.
HP troubleshooting document. http://www.hp.com/rnd/library/troubleshoot_lan.htm
4/14/2010 9:02:15 PM • HP ProCurve 2524... • Answered on Apr 14, 2010
Hp 4108 vs 2524
It has to be either the cable or the transcievers. Do you have a spare pair you can try instead?
Don't forget that HP has free tech support at 866-myprocurve also. They are excellent.
7/12/2009 3:29:53 AM • HP ProCurve 2524... • Answered on Jul 12, 2009
Network connections issue
Have you tried assigning a static ip to the computer.
6/20/2009 6:06:29 AM • HP ProCurve 2524... • Answered on Jun 20, 2009
Connection error
can you clarify the switch configuration, by default it will have all ports as untagged in the default vlan 1 with a bootp/dhcp address, I assume you will need to perform some kind of routing ie; default gateway, ip-helper address or static route to point to your routing device ADSL router etc try the following;
1~ configure an ip helper address on vlan 1 to point to what ever is supplying dhcp
2~ create a defualt route on the switch ie; 0.0.0.0 0.0.0.0 to next hop / routing device
3~ configure a default gateway ie; ip default-gateway x.x.x.x where x= routing device
the above can be accomplished via a serial connection to the switch using hyperterminal with the following settings
bits per second 9600
data bits 8
parity none
stop bits 1
flow control none
let me know if this resolves the issue
3/18/2009 10:14:14 AM • HP ProCurve 2524... • Answered on Mar 18, 2009
Connecting to console
The proper way to console to a switch (at least as far as Cisco Catalyst Switches are concerned) is a rollover cable and a DB9 adapter... I then use HyperTerminal to connect..
What type of switch are you connecting to, and what kind of hardware are you using?
I always use Cisco for networking (Cisco is the king of switches and routers).. here is their step by step for connecting to one of their swtiches:
http://tinyurl.com/b4o0
DG
12/26/2007 1:10:06 PM • HP ProCurve 2524... • Answered on Dec 26, 2007
2answers
How to configure VLANS and Tagging
https://m.youtube.com/watch?v=krE16IRIHw4 Watch this video for switch port access . You will need to be in global config interface mode.
10/20/2017 11:55:00 AM • HP ProCurve... • Answered on Oct 20, 2017
What is the default IP of HP ProCurve 2510-48 ?
There is no IP address when the switch ships from the factory. It is set by the user and/or the network by DHCP. If you do not know what the IP address was set to, then you'll need to return the switch ti it's factory default configuration. There should be information in the manual for the switch about the default config.
8/20/2014 5:32:38 PM • HP ProCurve... • Answered on Aug 20, 2014
Password prompt
Leave it blank to see if you can login.
8/20/2014 5:26:45 PM • HP ProCurve... • Answered on Aug 20, 2014
3answers
I need to know how to turn on a HP X13-04657 LAPTOP, all the lights are on but nothing on the screen.
HP X13-04657, is 2007 PC THOSE this PC has CCFL back lamp strip that is dead.Vista era PC, laptops. are hard to work with now, 17 years old.is this not a HP COMPAQ presario HP X13-04657 (wrong name!) sorry !became HP in 2002. so is HP but manuals are super hard to find now. that x13 is part of the microsoft license code vista. (so is distraction to what it is)the real name of the Laptop is and was Presario CQ61 laptop CQ61 the PC has bottom sticker that shows the real names of PCs.CQ61-219TU is real name of on CQ61, there area many different sub codes, and they are not all the same.CQ61-306AX this had CCFL (cold cathode florecent lamps) that love to fail 3 waysdead, blinks ,dime or yellow = white.was made until 2009 and evolved, to LED backlamps.-410 is CCFLI will answer for CCFL as those just love to fail,but the the test is so easynow the answer for ANY laptop this old. 2007 and older. black screen all the time, and BIOS screens dead, answers only me. here. remove the main battery (large) it simply snaps off the bottom.the power pack is next we run the PC on your power pack AC to DC it must make the screen glow with something, do not use the wrong pack as in mixed up with others.now the lap top seems on, even the fan blows, LED glowpoint a flash lamp at the screen ,dark' room , and of you see any kind of LCD data on the screenthe CCFL lamp below #1 is bad.this is phase 1 testing, as other things can fail too. The keyword below is Mercurythis tells me it is those pesky CCFL glow tubes. 2007 is the year some PC went to LED back lamps. yes I was correct the service manual I did find proves they made both lamp types ccfl-hp07-psnmcz4s4yabbrmds04n13cd-d-0.jpg
4/17/2024 12:37:57 PM • HP Computers &... • Answered on Apr 17, 2024
Dove posso scaricare il driver per HP ScanJet 8270? ente compatibile per windows 10...
Question edited for clarity. Question translated to English. We only speak English on this North American website. https://www.google.com/search?q=hp+scanjet+8270+driver+windows+10
HP Scanjet 8270 Document Flatbed Scanner
Hewlett-Packard https://support.hp.com > ca-en > drivers > hp-scanjet-827... Download the latest drivers, firmware, and software for your HP Scanjet 8270 Document Flatbed Scanner ... drivers free of cost for Windows and Mac ... Windows 10 / ...
Hewlett-Packard https://support.hp.com > ee-en > drivers > hp-scanjet-827... Download the latest drivers, firmware, and software for your HP Scanjet 8270 Document Flatbed Scanner. This is HP's official website to download the correct ...
HP Scanjet 8270 Document Flatbed Scanner drivers - Download
Softonic https://hp-scanjet-8270-document-flatbed-scanner-drivers.en.softonic.com Download the latest and official version of drivers for HP Scanjet 8270 Document Flatbed Scanner. This driver package is available for 32 and 64 bit PCs. It is ...
HP Scanjet 8270 Document Flatbed Scanner drivers - Free ...
Download.it https://hp-scanjet-8270-document-flatbed-scanner-drivers.en.download.it Download HP Scanjet 8270 Document Flatbed Scanner drivers varies-with-device. Software drivers for the 8270 flatbed model of the HP Scanjet printer. ..
4/10/2024 8:38:39 PM • HP Computers &... • Answered on Apr 10, 2024
2answers
HP 8440P Laptop. I don't remember my password. Help needed for HP 8440p.
This video shows you what to do if you forget your computer password:
4/6/2024 8:00:24 AM • HP Computers &... • Answered on Apr 06, 2024
2answers
How to do a bios recovery on a hp pavilion dv5-1004nr
This video shows you how to restore the BIOS in your computer:
4/6/2024 7:57:59 AM • HP Computers &... • Answered on Apr 06, 2024
Hp dv8 not charging battery
You can follow the steps in this video to troubleshoot your battery:
4/6/2024 7:13:37 AM • HP Computers &... • Answered on Apr 06, 2024
Hp supply central pin connected to the 19V power
  1. Central Pin: In many laptop power supply connectors, especially those using the barrel-type connector, there's a central pin that carries the voltage (typically around 19 volts for most laptops) to power the device.
  2. Voltage and Polarity: It's crucial to ensure that the voltage supplied by the power adapter matches the requirements of your laptop. Most laptops operate on 19 volts, but there are exceptions, so always double-check the specifications of your laptop and the power supply.
  3. Polarity: Additionally, the polarity of the connector is important. The central pin typically carries positive voltage, while the outer sleeve of the connector is the ground (negative). Reversing polarity can damage your laptop, so make sure the connector is inserted correctly.
  4. Safety: Always use the power adapter that came with your laptop or a compatible replacement from a reputable manufacturer. Using an incorrect or incompatible power adapter can not only damage your laptop but also pose safety hazards such as overheating or electrical fires.
  5. Replacement: If you need to replace your laptop's power adapter, ensure that the new adapter provides the correct voltage, polarity, and wattage for your laptop model. It's often safer to purchase adapters from the laptop manufacturer or certified third-party suppliers to guarantee compatibility and safety.
3/30/2024 8:53:24 PM • HP Computers &... • Answered on Mar 30, 2024
3answers
I got a 4 year HP laptop and it show a black screen and if I press Esc it will say Esc..start up and will do the same F2 and others.
If your laptop starts but the screen remains black, this video shows you the troubleshooting steps to follow:
3/27/2024 7:16:54 AM • HP Computers &... • Answered on Mar 27, 2024
HP ProCurve 2524 24x10/100 Mbps Networking Switch Logo
10 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
ProCurve HP
  • ProCurve HP
Most Popular Question
alignment rx error mean when
  • Computers & Internet
