20 Most Recent
NEC MobilePro 880 Questions & Answers
I am a Computer idiot. How do I instal drivers/apps?
You need to download ActiveSync 3.8 to your XP or earlier computer. It won't run with Vista. You also need a serial port to connect your mobilepro to your computer with the data cord that comes with the mobilepro. You can then sync your computer with your mobilepro.
Simple guide to get on net
if your laptop has not got built in wireless then you will need to use the wireless card, but not having a cd drive means you will have to go to the belkin web site for the drivers using somebody elses pc and download to a usb dongle or your own if its hard wired to a modem or router and download it to your hard drive
Software on the MobilePro system to connect to a Windows Terminal Server
Yes. You need to install the RDP client software which can be downloaded from Microsoft.
Procedure to install the RDP client on a MobilePro 880:
Note: Steps 1 and 2 need to completed if you have not installed the Service Pack One for MobilePro 780 and 880.
1. Perform a "Hard" reset on the MobilePro 880.
2. Install NEC Service Pack 1: http://support.neccomp.com/kbtools/faq/mobilepro/mp1.asp
3. Make sure the Device Name is set to something other than "Handheld PC".
1. Start-Setting-Control Panel-Communications
2. Change Device Name to a Unique Name that is not currently being used on your
network.
4. Establish a Partnership with a Host using active sync.
5. Disconnect the MobilePro from the host.
6. Install "hpcrdp.exe" on your host. It can be down loaded from Microsoft:
1. Go to http://www.microsoft.com
2. Select "Search microsoft.com" under the Search tab.
3. Type "hpcrdp" in the search box and depress Enter.
4. Look for the search results titled "Terminal Server Download for Windows CE".
5. Double click on the article and follow the link and at bottom of the Terminal Server License agreement you will find the link to bring down the RDP client.
7. Establish an Active Sync connection between the host and MobilePro 880.
8. The RDP client software will be installed on the Mobile device.
9. Install a NE2000 NIC (or any NIC that you have the MIPS CE drivers for) into the Mobile Pro 880.
10. Set up network and attach to your existing network.
11. Set up a RDP session:
1. Start-Programs-TerminalServerClient-Client Connection Wizard
2. Enter Description connection.
3. Server Name or IP address.
4. Next
5. Enter user name, password and domain if you want to logon automatically.
6. Next
7. Finish
If your terminal server is set up correctly you should be able to connect as a Client.
Service Pack
NEC Computers has developed a service pack to address several service issues with MobilePro 780 and 880 handheld personal computers.
To assure proper operation, NEC Computers strongly recommends that you update your MobilePro 780 and 880 systems immediately by installing this service pack according to the installation instructions.
* Download Service Pack One for MobilePro 780 and 880: ftp://ftp.necsam.com/pub/Catalog/3959/MobileProSP1.asp
* View Installation Instructions: http://support.necsam.com/mobilesolutions/FAQs/display/default.htm?itemID=2001186#Installation
* See Contents of Service Pack: http://support.necsam.com/mobilesolutions/FAQs/display/default.htm?itemID=2001186#Contents
* Read Additional Frequently Asked Questions: http://support.necsam.com/mobilesolutions/FAQs/display/default.htm?itemID=2001186#FAQ
Installation Instructions for Service Pack One for MobilePro 780 and 880
First download the service pack (MP78_UPDATE.CAB) to either your HOST or MobilePro system. It must be manually loaded onto your MobilePro by either using a dial up connection, PCMCIA Flash card, or from a connected PC before continuing with the installation.
To install the MP78_UPDATE.CAB file, follow these steps:
1. Back up your MobilePro data and configuration using the Microsoft ActiveSync backup procedure. For details on using ActiveSync, see your MobilePro User's Guide.
2. Perform a Full (hard) reset on your MobilePro.
Caution: Performing a Full reset erases all your data. Your MobilePro resets to the factory default settings. Please perform the backup first or you will lose data!
3. Copy the MP78_UPDATE.CAB file to you MobilePro desktop.
4. Install the service pack by double tapping the MP78_UPDATE ICON with your stylus. For proper installation, you MUST accept the default location - \Program Files, by clicking OK.
5. The following Message box will be displayed:
Warning !!!
1. In order to ensure these patches are properly installed you must perform a Hard Reset prior to the installation.
2. You must back up all application and data files before performing a Hard Reset.
The Hard Reset WILL ERASE all applications and data stored on this Mobile Device.
3. This file must be installed immediately after performing a Hard Reset on the Mobile Device (before any applications are reinstalled).
4. Press CANCEL to exit. Or Press CONTINUE to install this file.
6. Press Continue to install the service pack or Cancel to back up your data.
7. When the Setup Finish message box is displayed, Click Ok. This will remove all temporary files from your systems.
8. When the Setup Complete message box is displayed, click Ok.
9. Perform a Soft reset on your MobilePro.
10. Optionally, restore your MobilePro data using the ActiveSync restore procedure.
11. Once the service pack is installed, NECC recommends that you use the ActiveSync b
Updates for the PCMCIA and Compact Flash Card controllers
Some MobilePro units have exhibited the following symptoms when using Compact Flash Cards or ATA PCMCIA Memory Cards:
1. Storage Card folder is not displayed when you insert a PCMCIA ATA card and/or a Compact Flash card.
2. Warning message "Unidentified PC Card Adapter".
3. Warning message "Storage Card Warning" displayed.
To fix these issues:
If you have a MobilePro 750C without a ROM upgrade, download the file MP75Pcm.exe from support.necsam.com. For a MobilePro 750C with upgraded ROM, use the file MP75RPcm.exe. After the files are extracted, follow the instructions in the Readme.txt file.
Windows CE device
This error occurs because Windows CE first moves the file to the recycle bin before deleting it, and if there is insufficient space, the error message is displayed and the system appears to hang.
To resolve this issue, use one or more of the following methods.
* Empty the Recycle Bin
Use the following steps to empty the Recycle Bin:
1. Depress the "Alt" key and tap the Recycle Bin.
2. Tap "Empty Recycle Bin"
3. Tap "Yes" when asked to confirm the file deletion.
* Change the Properties for the Recycle Bin so that files are deleted instead of being moved to the Recycle Bin.
Use the following steps to change the properties of the Recycle Bin.
2. Tap "Properties".
3. Tap the check box for "Do not move file to the Recycle Bin, remove immediately on delete".
* To make additional space available for the Recycle Bin.
3. Tap the slider to the right.
"Fatal Application Error"
This problem may occur if the user allows the batteries to discharge to a state where the MobilePro must shut itself down. This state may cause the system storage memory to become unstable requiring a "hard" reset after the system has been fully charged again. Failure to perform the hard reset may result in data loss at a later time. The user manual states that if you receive a message indicating that the batteries are low, immediately connect the AC adapter to the device.
The solution is to perform a "hard" reset after fully charging the internal batteries, and then install the service packs, software updates and user software.
What software or cords do I need to get/run in order to get files to transfer to/from the NEC Mobilepro 770, or even get internet?
The NEC Mobilepro 770 is a legacy device that was released in the early 2000s and uses Windows CE as its operating system. Since the device is no longer supported, it may be challenging to find software and drivers that are compatible with modern operating systems like Windows 10. Here are some steps you can take to transfer files and connect to the internet:
- Get the necessary cables: You'll need a USB cable to connect the Mobilepro 770 to your Windows 10 PC. The cable should have a USB Type-A connector on one end and a mini-USB connector on the other.
- Install ActiveSync: ActiveSync is software that allows you to synchronize files between your Mobilepro 770 and your PC. Unfortunately, ActiveSync is no longer available for download from Microsoft, but you may be able to find an archived version of the software on the internet. Install ActiveSync on your Windows 10 PC and connect your Mobilepro 770 to your PC using the USB cable. If the device is recognized, you should be able to transfer files between the two devices.
- Connect to the internet: The Mobilepro 770 has a built-in Ethernet port that you can use to connect to a wired network. To connect to the internet, you'll need an Ethernet cable and a wired network connection. Plug one end of the Ethernet cable into the Mobilepro 770's Ethernet port and the other end into your router or modem. You should be able to browse the internet using the Mobilepro 770's built-in web browser.
- Install additional software: The Mobilepro 770 comes with a basic set of software, but you may want to install additional software to make the device more useful. You can download and install software from the internet, but make sure it's compatible with Windows CE and the Mobilepro 770.
Keep in mind that the Mobilepro 770 is a legacy device, and its performance and capabilities may be limited compared to modern devices. It's also possible that some of the software and drivers you need may no longer be available or supported.
