20 Most Recent
Samsung S5830 Galaxy Ace Onyx Black Android 2.2 OS unlocked phone Questions & Answers
I need to use my galaxy just for texting & calls +phone how can i clear the phone of any other data , so as to to use less money on pay bas you go help!!
go to settings,,,,,privacy,,,,,factory data reset,,,this will wipe everything off your phone and go back to original factory settings, but beware if you want to keep all your contacts etc. you must put them on sd card or sim card because everything will be wiped off
Cant download pictures sent by text
hi there i had a similar problem with a phone i had to phone my network provider and they had to send new information to my phone and it started working you could try this!
Free NUC for Samsung Galaxy Ace
Hi, You can get the unlock code for your Samsung Galaxy Ace from your service provider or from any online sites!!! Free unlocking service may not always be safe, so it is better to choose a paid reliable unlocking service.I would recommend
Prounlocking.com , they provide perfect codes at reasonable price!!!
Unlock code
Hi, you can unlock a Samsung Galaxy Ace using unlock code. You can get the unlock code for your mobile from
www.unlocking4u.com at affordable cost.
My Samsung Es90 digital camera's shutter is not working, plus, the batteries are fully charged but when inserted, it only last 2-3 minutes. What can I do to resolve this?
I'm assuming by "shutter" you're referring to the one inside the camera and not the cover blades on the very front of the lens.
How old is the battery and do you use the camera a lot?
Old batteries can be fully charged but can become weak and not hold that charge when the camera is powered on. The shutter issue could be part of this as the battery might not be strong enough to power the shutter.
I think the batteries for these cameras are reasonably cheap so you could invest in a new one to see if that helps. An extra battery is always useful if you use the camera a lot.
If this is an old, well used camera part do wear out so if new battery doesn't help you may need to take it to a good repairer as the camera will need to be taken apart to find the problem.
Samsung Digimax 301 will not turn on only green light flashes
- Check battery polarity: Ensure that you have inserted the AA batteries correctly, aligning the positive (+) and negative (-) ends as indicated by the camera's battery compartment. Improper battery placement can prevent the camera from powering on.
- Clean battery contacts: Over time, battery contacts can accumulate dirt or corrosion, hindering proper electrical connections. Use a clean, dry cloth or a cotton swab dipped in rubbing alcohol to gently clean the battery contacts inside the camera's battery compartment. Make sure to let the contacts dry before reinserting the batteries.
- Replace batteries: Even though you inserted fresh AA batteries, it's possible that they may not have sufficient power to operate the camera. Try using a different set of new batteries or fully charged rechargeable batteries to eliminate the possibility of a power issue.
- Reset camera settings: Some cameras have a reset option that restores the default settings, which can help resolve certain issues. Look for a small reset button or a menu option within the camera's settings to perform a reset. Refer to the camera's user manual for specific instructions on how to reset your Samsung Digimax 301 model.
- Firmware update: If your camera has an outdated firmware version, it may cause compatibility issues or malfunctions. Check the Samsung website or contact their support to see if there are any firmware updates available for your camera model. Follow the provided instructions to update the firmware if necessary.
