20 Most Recent
Samsung SCH-i600 Questions & Answers
Hi
I have a SGH i600
A common reason that a device cannot connect to WMDC is that the firewall prevents it. You can check it out by temperately disabling the firewall. If that's the cause, please follow the steps shown in the following article(If it doesn't work.... #2):
TROUBLEShooting VISTA Windows Mobile device Center
http://blogs.msdn.com/b/jasonlan/archive/2006/12/11/troubleshooting-vista-windows-mobile-device-center.aspx
Another reason would be the necessary driver is not installed or is not installed properly. To install the driver, use "Windows Update" when your device is connected. To repair the installation of the driver, please follow steps described in the segment "Troubleshooting tips" in the following article:
Windows Mobile Device Center (WMDC) troubleshooting guide
Also you can download the drivers from thebelow link
http://gigabitdownload.com/search/samsung+sgh+i600+sync+software+for+windows+7
I600 displays "phone off"
hi
either you change your battery or change the display or you can contact your service.they will fix your problem
thank you
I have a Samsung phone.
press and hold the harsh key "#" on of your phone. Or while you are making a call, press option an d you will see mute amongst the list.
While making call, you can press the arrow button on your phone to the right.
Good luck.
I have a samsung Omnia pnone and it just turns its
I think that you should take the samsung to a shop and ask for it to be reflashed, it may be a common software or hardware problem. If you still have warranty on your phone it can be fixed at no cost.
I just purchased a MicroSD card for my new Samsung
Check the manual, and make sure the card you are using isn't larger in capacity than your phone accepts.
I have encountered a problem where the contacts on the card don't easily mesh with the electrical contacts on the phone. May sure the card is inserted the right way, and clicks into place.
How to make a call via OT-020C blue tooch
I have a OT-020C BT headset and once paired to my Sanyo SCP-3200 phone, I tap the power/control button on the headset and say who I want to call. The voice-recog in the phone does the rest, usually. Of course it doesn't work in noisy areas so then press [END] and manually dial the number.
Problem Picking up certain network
it is possible that your phone is locked to a specific network, and will not allow you access another sim card from a rival network. you will have to get your phone unlocked and it will then accept different networks. you will have to ring your network provider that supplied the phone and get them to give you the unlock code..or you can use various internet like http://www.unlockitnow.com/
Reset or hard reboot
hey here is the manual for your phone take a look at it and see if you can find the info you are looking for. Alright.
USING SPEED DIAL ON SAMSUNG I600
Hi Linesh
Just had a look through the i600 manual and this is how you save a speed dial:
1. On the Home screen, press the Contacts soft key. You
can also press the Start soft key and select Contacts.
2. Select a contact from the list.
3. Scroll to a number, e-mail address, or web page
address.
4. Press the Menu soft key and select Add to Speed Dial.
5. If necessary, enter the name you want.
6. In the Keypad assignment field, select a location.
7. Press the Done soft key
Hope this helps.
