20 Most Recent
Horizon T202 Treadmill Questions & Answers
Horizon t202 treadmill makes a constant beeping
1) adjust the REED switch see the diagram attached. Clean it+ 2)test for open or faulty 3) tight the connector very well.2) tight the upper and lower connectors very well and clean it.3) inside from console tight the ribbon cable and clean itGod bless you
When I plug in my treadmill there is a continuous
1) adjust the REED switch see the diagram attached. a) test for open 2) clean it 3) tight the connector very well and clean it2) tight and clean it the upper and lower connectors.3) tight and clean the ribbon cable inside from Display.God bless you
My horizon t202 treadmill wont start i cant even located the on/off switch where is that? I see the reset button
Normally the button and reset is in FRONT from the machine is you stand from the machine in the lower part, Is RED and at the side is reset button.2) Test the fuse inside see the block diagram , test and replace.3) Test the power cord for open, break4) test the outlet wall, reset the breaker from you house, DO not use any extension cord. and proof again.5) If you can NOT resolve the problem, you must call to the service tech,.maybe you have problem with some component, inside capacitor, transformer in the power supply.God bless you
Does the Horizon 7.0 AT have a fuse on the MCB?
Hey Sharon,Hope so you're doing fine, there is typically no separate fuse on the MCB (Main Circuit Board). The MCB itself is responsible for controlling the incline and belt functions of the treadmill. If the top board turns on but the incline and belt do not run, and the MCB is flashing a safety key error message, it suggests that the safety key might not be properly engaged or there could be an issue with the safety key sensor.To troubleshoot the problem, make sure the safety key is securely inserted into its slot and properly aligned. Check for any visible damage or debris that might be obstructing the safety key sensor. If the issue persists, it is recommended to consult the treadmill's user manual or contact Horizon customer support for further assistance. They can provide specific troubleshooting steps or guide you through any potential repairs or replacements that may be necessary.Hope so this will work for you!Regards,Bryce JuneCEO & Founder of https://bbcorhitter.com/
Horizon T202-4 motor hot and burning smell
It sounds like there may be a problem with the control board or the wiring of the treadmill. The high temperatures you are experiencing on the control board and motor are not normal, and can cause damage to the machine.
Here are a few things you can try to troubleshoot the issue:
- Check the wiring of the treadmill to ensure that all connections are secure and that there is no damage to the wires.
- Make sure the motor is properly installed and that the belt is aligned and tightened correctly.
- Check the ventilation of the motor and control board to ensure that they are not overheating due to a lack of proper airflow.
- Check the amp draw of the motor and compare it to the specifications of the machine to ensure that it is operating within normal range.
- If the problem persists, it may be best to contact the manufacturer or a qualified technician for further assistance.
It's also worth noting that, it may be the case that the new motor sent to you is faulty, or that the problem is not the motor itself but with another component of the treadmill.
It may be a good idea to have a professional look into this issue and diagnose the problem before trying to replace another component.
Horizon Quantum Incline not working
The issue you are experiencing with the incline motor on your Horizon Quantum II treadmill could be caused by a variety of factors, including a problem with the motor itself, the control board, or the wiring. Here are a few steps you can try to troubleshoot the problem:
- Check the motor: As you mentioned, you were able to operate the motor when 230V was applied, which suggests that the motor itself may be functioning properly. However, you may want to test the motor further to confirm that it is not the cause of the issue.
- Check the control board: The control board is responsible for controlling the incline motor, as well as other components of the treadmill. If the control board is damaged or malfunctioning, it could be causing the issue you are experiencing. Test the board to see if it is functioning properly.
- Check the wiring: The wiring between the control board and the incline motor may be damaged or malfunctioning, which could be causing the issue. Check the wiring for any visible damage or loose connections, and test it to see if it is functioning properly.
If you are unable to troubleshoot the issue using the steps above, or if you are not comfortable working with electronic components, it is recommended to seek the assistance of a qualified technician to diagnose and repair the treadmill.
Omega 3 treadmill - Does anyone know what might be
replace the old batteries (if your system have batteries, clean the contacts batteries) put a new ones.2) adjust the REED swtich see the diagram attached.3)tight the ribbon cables inside from display board and clean it. tight and clean the upper and lower connector. and try again.God bless you
