20 Most Recent
Creative Labs Inspire T2900 Computer Speakers Questions & Answers
Volume goes up and down by itself
- i think the problem is due to dust
- using a vaccum cleaner or use a painting brush for clean the IC legs and ciruit
- check loose conection of the control
- the dust mis function the chip inside
wish you all the best
The speakers dont work even
if your computer came with
a motherboard disc the sound drivers could be on it
click start control panel
administrive tools computer management device manager scroll to sound,video and
game controllers you might see a yellow question exclamation mark? ! or a red X
Right click to reinstall drivers if you dont have a motherboard disk you will need to download the sound drivers
sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers)))
also audio you will find 3 drop down lists make sure you have the correct
settings there
also
sounds and audio devices select advanced there might be a tick in the mute box
untick it
if his does not fix the
problem
sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place
icon in taskbar for any further volume control settings you will need to right
click on the volume icon system select
adjust volume
click start control panel sounds and
audio,volume,advanced,speakers select the appropriate speakers from the drop
down list or navigate to the device manager scroll to system devices + to
expand,system speaker right click properties then select use this device
(enable) also you might check
the speakers plug/outlet is
usually at the back of the computer you will have to open up the computer
to check the lead attached to the rear of the input plug make sure the
connection is good
try cleaning your computer of dust using a fine air blower from a
compressor making VERY sure that there is no MOISTURE in the air line
specifically around the sound card and the CPU central processing unit dust
causes static to build up in a computer if you need more help with this posta reply hope this
helps
The problem on my speakers
Id try to find another power supply to plug into them with the same voltage. Usually 9-12 volts. Walmart,radio shack, or kmart have universal power supplies you can purchase to test them. Maybe keep the receipt and return it on the chance that it still doesnt work(in which case you'll need a new set of speakers).
No sound at all
hey buddy,u check de drivers installed on pc, or check the adapter joints it gets loose contact,or check have put on the on button in its back side...check to some electrician whether ur adapter is working...check all de joints of wires...dont dis mantle ne thing...if nothing happens handel to suitable service center...
ne other prob's do tell me..N plz do rate me
cya
Hi, Is there a plug that will allow bulk printing
You can use this ONLINE tool from eBAY. ITS COMPLETELY FREESelling Manager is an online tool designed for medium-volume sellers to help
manage and track listings on eBay. Selling Manager is conveniently located in My
eBay. Use with Turbo Lister for a complete solution.
• Monitor active listings
• Generate bulk feedback and print invoices
• Print invoices and labels in bulk
Bulk Printing (Selling Manager Pro)
Selling Manager Pro subscribers can print as many as 200 invoices or shipping
labels at one time from the Sold View.
To print multiple invoices and shipping labels:
In the Sold View, check the box next to the listings that you want to print
invoices or shipping labels for and click the Print button.
To select all of your Sold items, check the box in the heading bar above
the list of sold items
From the Print page, select the printout you want, and click the Continue button.
In the pop-up window that appears, use the scroll bar to preview each of the
pages that will be printed.
Once you are satisfied with how the pages will look, click the Print button in the browser window.
If you need to edit information for a specific page, go the corresponding
sales record. When you are finished updating the sales record, save your
changes. Your changes will be reflected the next time you print.
This pro version is available for approx $5 per month
My IC BT9843 is burnt I need an equivalent to replace it.any help please?
Try searching again using Google, using BT 9843, but when you look down the results ignore the two letters and see if you can find an IC which is the same numbers, even if it has different letters on the front. Those letters could be just the makers letters, with the device made by different makers.
Barely see screen
If the brightness is all the way down, simply turn it up.
If not this indicates an issue with the device and you should take it to your local tech repair shop
