You must upgrade your Audible subscription to get transfer rights - if you ever let your subscription expire, you can kiss those play rights goodbye - this is the cold new world of mp3 player services
To download music from internet you need a down loader.
First, download lime wire go to (www.download.com) search lime wire. After you have search the lime wire click it and download. Once you have already downloaded the lime wire install it. The lime wire icon are shown in the desktop now you can start to download a music.
Second, open the lime wire icon shown in the desktop search the artist of the music. Once you have already search the artist all music title of the artist are shown there chose and click the music title you want to download. The download process are shown at the bottom of open lime wire. Once the download process reach to 100% it is shown complete.
Third, if the download complete you can locate it in the folder where the lime wire installed. To locate you can right click the music which is completely download. Right click it and you can read there where the music located. Good luck and more power, thanks for using fixya.
The previous poster is right; I do repairs on these all the time, and the most common problem is a cracked screen. The crack is on the back so you can't see it. The screen will need to be replaced.
I had the same problem: "Playback error", and nothing i did, helped. But when i pushed the reset buttom, below the on/of button, it turned of, and when i switched it on again, it worked. Maybe you could try again?
Otherwise I say this on YouTube, but thought it was a little drastic ;-)" />
HOLLLYYYY CRRRRAAAAPPP i found out how to fix it!!!! now, to be alittle more civilized, i pried off the plate covering the button interface thingy, then i took off the plate that covers the screen. now, with the actually screen exposed (was a plastic screen... protector) you very gently pull on the exposed screen.okay, there will be sticky foam thing that were keeping the screen from moving or whatever, and that will come loose, nothing has broken. i dont know any technical terms, but there is a filmy thing connecting the screen to the circuits and all such stuff. also, there is brown tape covering that to make sure it stays in place i guess. mine had come a little loose, so i messed with it for a while, made sure it was all connected, and put some more tape to make sure it stayed in place. now it works again!!! i hope it works for you good people of the internet. maybe i have stumbled upon the answer to the greeeeeeaaaaaaat queeeeesstiiiooonnn. post some kind of response if this works for you i hope it has helped.
push and hold the power button and at the same time prss the play button....a system recovery window eill pop up and select the first optiom "clean up" then turn it off and on again and its done!
:D
