20 Most Recent
Samsung Un55d6050 TV Questions & Answers
No sound on my samsung smart tv
you might need a fix it kit some mother boards e prom go bad seen this a lot i have a 32 Samsung doing that same thing check ebay with the number of the board starts with bn
5/30/2015 2:18:03 AM •
Samsung...
Answered
on May 30, 2015
Screen wont come on red light just blinks
this is a common failure in this set it does have to do with the power supply but there is more this set shuts down the way it does for the reason of bad led strip. some of your led's are burnt up it has 2 rows one on each side of the tv. very hard part to find. and lots of work you have to take the screen completely apart
5/30/2015 1:30:06 AM •
Samsung...
Answered
on May 30, 2015
Samsung 5 blink code
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
10/27/2017 12:21:54 PM •
Samsung UN...
Answered
on Oct 27, 2017
Samsung LCD TV UN55C7000WF will not turn on
Fault at its main digital board.
Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Led tv will not power on
Secret menu ? If you mean factory setup menu then might have to replace the digital main . When in that menu you have to be careful or its replace the board time !
