20 Most Recent Gemini Sound Products Gemini Cdj-210 Tabletop Scratch Mp3/cd Player Questions & Answers
0answers
Reset
Be the first to answer 6/30/2013 11:47:24 PM • Gemini Sound... • Posted on Jun 30, 2013Be the first to answer
2answers
How do u check pcb board on musical equipment and on other equipment the only tool i have to check is a Fluke Multimeter but is there any other stuff that is need to inspect and Diag. these boards ple
One of the first things a technician does with a voltmeter it to check 'all the voltages' in a system are correct.. Even without a specific circuit diagram for the board, 'Applications Notes' for chips and seminconductors will give nominal expected voltages in a working circuit. Remember you can burn out the meter by connecting it to any source of current when on the Ampere or Ohm settings. Technicians usially start at a high (highest) Voltage range setting and work downwards.. Providing the maximum Voltage is not exceeded on any range, whether it is AC or DC will not damage the meter. 'Fluke' by the way are a 'top end' professional product - check the price ;)
11/30/2014 7:41:59 AM • Gemini Sound... • Answered on Nov 30, 2014
0answers
0answers
Speaker fuse
Be the first to answer 11/24/2013 3:47:37 AM • Gemini Sound... • Posted on Nov 24, 2013Be the first to answer
Peavey cs1000 x
The most likely case is that one of the main output transistors (if which there are many) is shorted. When the protect circuit senses DC on the final output, it will not allow the output relay to come on to protect the speakers from raw DC. With the power removed, you can check between each outputs Emitter and Collector and you will probably find close to zero ohms. From that point you need to unsolder each of the pins of the bad channel until you find the shorted device(s) and replace them.
2/7/2024 9:32:20 AM • Music • Answered on Feb 07, 2024
2answers
FRONTIOPAE what is this instrument unscrambled
'pianoforte'
1/17/2024 4:22:56 PM • Music • Answered on Jan 17, 2024
Looking for specific screw for a Crate and Barrel table
BREV. N. 838420
1/9/2024 8:32:24 PM • Music • Answered on Jan 09, 2024
I want to manually wire my z-560
1/4/2024 1:18:20 PM • Music • Answered on Jan 04, 2024
Electronic drum
See page 22 troubleshooting of this manual. It may help you. dd501 (yamaha.com)
1/3/2024 2:26:52 PM • Music • Answered on Jan 03, 2024
No or very little sound from Fender passport
Depending on the model, there are four around that date, it could be the insert jacks are tarnished reducing the signal flow between the pre amp stage and digital power amplifier. It could be the power amplifier has failed. It could even be customer error in wiring. This assumes there is the correct level of signal entering the input sockets of course.
12/31/2023 8:25:12 AM • Music • Answered on Dec 31, 2023
What song did these lyrics come from. (You can set by the water but you just can't drink )
Are you sure you are quoting accurately? Could it be one of these instead? http://www.lyrics.cat/lyrics+lead+a+horse+to+water
12/27/2023 3:43:51 PM • Music • Answered on Dec 27, 2023
Line 6 spider ii head sounds like crap on insane red setting
It's a Line 6 and probably requires a software update from Line 6.
12/24/2023 7:57:43 AM • Music • Answered on Dec 24, 2023
Pricesof yMh PSR 9000 KEYBOARDS
  • Price:$1,099.99 on amazon
11/14/2023 7:53:13 AM • Music • Answered on Nov 14, 2023
Breaking Roland RD 600 hammers
The Roland RD-600 is a digital piano, and its hammer action mechanism is designed to simulate the feel of an acoustic piano. The hammers in digital pianos like the RD-600 are typically made of materials like plastic or a combination of materials to replicate the weighted feel of acoustic piano keys. The breaking of hammers in a digital piano is not a common issue, and it's not typically related to the age of the instrument alone. Several factors could contribute to the breakage of hammers, and it's essential to consider the following possibilities:
  1. Excessive Force: If the keys are played with excessive force or if there's any physical damage to the instrument, it could lead to the breakage of hammers.
  2. Material Quality: The quality of materials used in the construction of the hammers can impact their durability. If the hammers are made from subpar materials, they may be more prone to breaking.
  3. Manufacturing Defects: In some cases, there could be manufacturing defects that make the hammers more susceptible to breakage.
  4. Maintenance: Lack of proper maintenance, such as cleaning and regular inspection, may contribute to the wear and tear of components, including hammers.
If you've observed a pattern of hammers breaking with regularity, it might be worth investigating the specific cause. If it's due to excessive force or physical damage, adjusting playing habits and taking care during transport can help mitigate the issue. As for whether it's worth purchasing new hammers from Roland, it depends on the extent of the damage and the overall condition of the instrument. If the RD-600 is in good condition otherwise and you enjoy playing it, replacing the hammers could be a reasonable option. However, you may want to assess the cost of replacement hammers compared to the overall value of the instrument, factoring in the cost of a used RD-600 and any potential future maintenance needs.
11/12/2023 2:54:05 PM • Music • Answered on Nov 12, 2023
Gemini Sound Products Gemini Cdj-210 Tabletop Scratch Mp3/cd Player Logo
4 questions posted
Top Gemini Sound Products Music Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Gemini Sound Products Music Expert? Answer questions, earn points and help others
View Most Popular
  • Gemini Sound Products Music
Most Popular Question
u check pcb board musical equipment
  • Music
