20 Most Recent Gemini Sound Products Gemini Cdm-3610 Mp3/ Cd Player W/ Mixer System Questions & Answers
I dont know how to set up a mixer Gemini 3610 to my laptop and my powered speaker i want to know what cables i need
There are several possible solutions for this. The cheapest and easiest is to do the following:Solution 1:1. Get an RCA stereo plug to 3.5 mm plug. This will go from your mixer to your computer. This will not be the highest quality, but will work.2. Get an XLR cable of the length you need. I would guess a standard one with a male connection on one end and a female on the other. Connect this to your powered speaker. Also, this is a guess as you didn't include the type of powered speaker, so I can't tell you for sure which cable to use.Solution 2:1. An alternate idea for better sound quality would be to run a D/A converter similar to this one: http://www.sweetwater.com/store/detail/USBMix/It would give you a much higher sound quality for everything. You would run from your Gemini to this. From this device, you would run a USB cable to your computer, and a 1/4" cable to your powered speaker.
7/20/2012 12:55:45 PM • Gemini Sound... • Answered on Jul 20, 2012
NO SOUND OUT PUTPUT? RCA
your RCA from your mixers output has to go into the input of your amp. just switch that and you should be fine
5/14/2011 3:09:42 AM • Gemini Sound... • Answered on May 14, 2011
I want to connect Gemini Cdm-3610 to my TV can i
You can probably patch the audio into the audio input jacks of the TV, however without a video signal there would be no picture on the TV, only audio... It is also possible that without a video signal, the TV may mute the audio inputs...
12/13/2010 6:30:53 PM • Gemini Sound... • Answered on Dec 13, 2010
2answers
How do u check pcb board on musical equipment and on other equipment the only tool i have to check is a Fluke Multimeter but is there any other stuff that is need to inspect and Diag. these boards ple
One of the first things a technician does with a voltmeter it to check 'all the voltages' in a system are correct.. Even without a specific circuit diagram for the board, 'Applications Notes' for chips and seminconductors will give nominal expected voltages in a working circuit. Remember you can burn out the meter by connecting it to any source of current when on the Ampere or Ohm settings. Technicians usially start at a high (highest) Voltage range setting and work downwards.. Providing the maximum Voltage is not exceeded on any range, whether it is AC or DC will not damage the meter. 'Fluke' by the way are a 'top end' professional product - check the price ;)
11/30/2014 7:41:59 AM • Gemini Sound... • Answered on Nov 30, 2014
0answers
0answers
Speaker fuse
Be the first to answer 11/24/2013 3:47:37 AM • Gemini Sound... • Posted on Nov 24, 2013Be the first to answer
Peavey cs1000 x
The most likely case is that one of the main output transistors (if which there are many) is shorted. When the protect circuit senses DC on the final output, it will not allow the output relay to come on to protect the speakers from raw DC. With the power removed, you can check between each outputs Emitter and Collector and you will probably find close to zero ohms. From that point you need to unsolder each of the pins of the bad channel until you find the shorted device(s) and replace them.
2/7/2024 9:32:20 AM • Music • Answered on Feb 07, 2024
2answers
FRONTIOPAE what is this instrument unscrambled
'pianoforte'
1/17/2024 4:22:56 PM • Music • Answered on Jan 17, 2024
Looking for specific screw for a Crate and Barrel table
BREV. N. 838420
1/9/2024 8:32:24 PM • Music • Answered on Jan 09, 2024
I want to manually wire my z-560
1/4/2024 1:18:20 PM • Music • Answered on Jan 04, 2024
Electronic drum
See page 22 troubleshooting of this manual. It may help you. dd501 (yamaha.com)
1/3/2024 2:26:52 PM • Music • Answered on Jan 03, 2024
No or very little sound from Fender passport
Depending on the model, there are four around that date, it could be the insert jacks are tarnished reducing the signal flow between the pre amp stage and digital power amplifier. It could be the power amplifier has failed. It could even be customer error in wiring. This assumes there is the correct level of signal entering the input sockets of course.
12/31/2023 8:25:12 AM • Music • Answered on Dec 31, 2023
What song did these lyrics come from. (You can set by the water but you just can't drink )
Are you sure you are quoting accurately? Could it be one of these instead? http://www.lyrics.cat/lyrics+lead+a+horse+to+water
12/27/2023 3:43:51 PM • Music • Answered on Dec 27, 2023
Line 6 spider ii head sounds like crap on insane red setting
It's a Line 6 and probably requires a software update from Line 6.
12/24/2023 7:57:43 AM • Music • Answered on Dec 24, 2023
Pricesof yMh PSR 9000 KEYBOARDS
  • Price:$1,099.99 on amazon
11/14/2023 7:53:13 AM • Music • Answered on Nov 14, 2023
Gemini Sound Products Gemini Cdm-3610 Mp3/ Cd Player W/ Mixer System Logo
7 questions posted
Top Gemini Sound Products Music Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Gemini Sound Products Music Expert? Answer questions, earn points and help others
View Most Popular
  • Gemini Sound Products Music
Most Popular Question
dont know set up mixer gemini 3610
  • Music
