20 Most Recent
Phonic Powerpod 1860 Plus Powered Mixer Questions & Answers
Need a manual
http://www.bgaudio.eu/products/prod00000051/um_Powerpod1860Plus_PowerpodK12Plus_PowerpodK16Plus_en_es_cn.pdf
Occassional noise when adjusting high
Typically anytime you can move a pot,fader,switch etc. And It makes any kind of noise such as static it's likely that it is justa dirty component. Deoxit is the most used cleaner. Most pots have some kind of opening on base that you can spray into if not then just directly down at the collar is where to spray. Spray all dirty controls and excursive by twisting pot.
Phonic Powerpod 1860 - One channel xlr input
Several things could cause this... connecting it to a piecee of equipment powered from a different wall receptacle cound result in ground bounce on the building power that could destroy the input circuits. Another thing is if a static discharge hit it... There are bypass capcitors at the inout that could have shorted. Of course the fader could have failed...
Turning my Phonic PowerPod7 into a home stereo
To turn your Phonic PowerPod 7 into a home stereo system, you will need to make some additions and connections to the existing setup. Here are the steps you can follow:
- Connect speakers: You will need to connect a pair of passive speakers to your PowerPod 7. You can do this by connecting the speaker cables from the speakers to the "Speaker Outputs" on the back of the PowerPod 7.
- Add a source: The PowerPod 7 has two channels, so you can connect a stereo source such as a CD player, turntable, or music streamer. Connect the left and right audio outputs of the source to the corresponding inputs on the PowerPod 7.
- Connect to power: Make sure to plug the PowerPod 7 into a wall outlet to power it on.
- Adjust the volume: Use the volume knob on the PowerPod 7 to adjust the overall volume of the system.
- Tune the sound: If desired, you can adjust the tone controls on the PowerPod 7 to tailor the sound to your preferences.
With these steps, you should have a functional home stereo system using your Phonic PowerPod 7.
2/13/2023 11:57:30 AM •
Phonic Music
Answered
on Feb 13, 2023
Purchased a Phonic 740plus. Can't get the 16 channel effects to work. Manual is vague in this area. I seem to have everything set properly but it doesn't work. Does this need to go out to another amp?
Getting Started
1. Turn all power off on the Powerpod mixer. To ensure this, the AC cable should not be connected to the unit. 2. All faders and level controls should be set at the lowest level to ensure no sound is inadvertently sent through the outputs when the device is switched on. All levels should be altered to acceptable degrees after the device is turned on. 3. Plug all necessary instruments and equipment into the device's various inputs as required. This may include line signal devices, as well as microphones and/or guitars, keyboards, etc. 4. Plug any necessary equipment into the device's various outputs. This could include speakers, monitors, signal processors, and/ or recording devices. NB. No devices other than speakers should be connected to the power amp outputs. Plugging inappropriate devices into the mixer will likely cause damage to the device. Also, guitar cables should not be used to connect amplifiers to speakers. 5. Plug the supplied AC cable into the AC inlet on the back of the device, ensuring local voltage level is identical to that selected by the Voltage Selector on the rear of your device. 6. Plug the supplied AC cable into a power outlet of a suitable voltage. 7. Turn the power switch on.
5/5/2021 12:50:53 AM •
Phonic Music
Answered
on May 05, 2021
