20 Most Recent
Numark Industries Numark 5000FX 5 Channel Mixer Questions & Answers
Serious Doubts of Authorized Delaers
I think you have been lucky! Many manufacturers do not want you to do your own servicing or updating, and guard their Technical stuff jealously. Letting anyone use it opens it up to copycat manufacturing.
12/12/2020 6:36:32 AM •
Numark...
Answered
on Dec 12, 2020
Not receiving STEREO output when toggle switch for mixer is in the STEREO position
Here are a couple of steps you can do first before opening up the mixer & I'll word this so that it covers every potential item, (Turntables, CDJ's, Rack Mount CD Players, External Player, PC, Laptop, etc.) Obviously there are a multitude of items that could be the cause of you only receiving your RIGHT MASTER OUT since you didnt specify what item this occurs with if not all. So here's a quick legend for you to follow my references regarding the NUMARK 5000FX Mixer so here we go:
MIC/Line Phono/CD Phono/CD Phono/CD LA/LB Zone/Booth/Rec/MSTR
LO LO LO LO LO LO LO LO LO LO LOLOLO LO
RO RO RO RO RO RO RO RO RO RO RORORORO
1. Turntables - A) If being used make sure the little black switch on the back is set to Phono instead of CD. Plug just one table in, play the record & see if there's only one side of your MASTER output jumping and make note of it. Then repeat the exact same steps for all Phono inputs (total 3) & again make note of your MASTER output signal Left or Right or Both sides jumping. This will help you identify if its just a specific channell that only works on R or L.
B) Now do the exact steps above for the other turntable & this will confirm whether or not the Phono cables went bad on the turntable or if a specific channell is has gone bad while in Phono mode.
2. CDJ's/Rack Mount CD Player - A) Now just use your CDJ's/Rack Mount CD PLayer for the next test & be sure to now change the little black switch on the back from Phono to CD. Just as the steps with the turntable perform the same for this item in all possible RCA's (total 6) & note your MASTER channell output signals L & R.
B) Now do the same for the other CDJ/Rack Mount CD Player & this will confirm whether or not the RCA cables went bad on the CDJ's/Rack Mount Player or if a specific channell has gone bad while in CD mode.
3. Audio Cables OUT - A) There are a host of ways to have your audio come OUT & multiple configurations depending on how you record &/or bounce your audio OUT. Now since you say your MASTER OUT digital meter is only jumping on the R side depending on if you're going with RCA MASTER OUT or XLR BALANCED MASTER OUT either or is what'll show the digital reader bouncing with audio so check both. It could very well have been a cable going bad on you simple as that & you can check that by pluging your cable that works on the R side into the L side. If it starts showing a reading on the digital meter than you've solved the problem being a bad cable. Also don't forget to check your ZONE, BOOTH & RECORD OUTS as well however these will not show on your digital meter so open up your audio recording software to confirm that L & R sides are working for these.
B) Last but not least double check that your BALANCE knob is set directly at 12 o'clock, this could sometimes be the culpret.
Well I hope this helps & good luck.
WesTCo@sT">
3/9/2014 7:16:34 AM •
Numark...
Answered
on Mar 09, 2014
Numark 5000FX power
***Please read this reply in its entirity because there's more information way down at the bottom of the reply. Now the below Pro-Audio International Supplier Thormanne, had the power supply for the Numark FX5000. That's where I bought mine and it was shipped fairly quickly. Also here's the part number from my order so you know you're getting the very specific power supply the FX5000 requires.*** 1 Stck order code 188821----------------------------------------------------Numark Power Supply for Numark 5000 FXeach 42.85 EUR, total 42.85 EURTel,-0049-9546-9223-641Fax,-0049-9546-9223-24
[email protected]Musikhaus Thomann e.K.Treppendorf 3096138 BurgebrachGermanyhttp://www.thomann.deApantiseis stis perissoteres erwtiseis sas, mporeite na breite edw:
http://www.thomann.de/gr/faq_99.htmlHRA Bamberg Nr. 8988
Also so you are aware you're going to need to pick up an eletrical convertor for electronics built with EURO specs but allows to down step the current to what it is in America. Any Fry's Electronics or Pro-Audio store here in the US will have the one I bought which is a - MODEL: TC-100A Up/Down Convertor $45.00.That's it and my mixer is playing wonderfully so there you have it.Thank you.
10/6/2013 11:52:17 PM •
Numark...
Answered
on Oct 06, 2013
How do is fix my Numark m6 bleeding cross fader
/it's most likely a defective fader, but before replacing it, get a can of Deoxit5 or fader cleaner and spray inside the fader, then move it the full length os travel about 20 times to see it that clears it up.
7/10/2016 2:58:13 AM •
Numark Music
Answered
on Jul 10, 2016
Anybody you know who restore
Most turntables require a new drive belt. The cartridge sometimes needs replacing. Cahngers require much more maintenance. Hardly anybody does this anymore... but if belt has deteriorated, that is DIY as you can find suppliers of the belt online.
8/19/2011 7:05:21 PM •
Numark Music
Answered
on Aug 19, 2011
Peavey cs1000 x
The most likely case is that one of the main output transistors (if which there are many) is shorted. When the protect circuit senses DC on the final output, it will not allow the output relay to come on to protect the speakers from raw DC. With the power removed, you can check between each outputs Emitter and Collector and you will probably find close to zero ohms. From that point you need to unsolder each of the pins of the bad channel until you find the shorted device(s) and replace them.
2/7/2024 9:32:20 AM •
Music
Answered
on Feb 07, 2024
No or very little sound from Fender passport
Depending on the model, there are four around that date, it could be the insert jacks are tarnished reducing the signal flow between the pre amp stage and digital power amplifier. It could be the power amplifier has failed. It could even be customer error in wiring.
This assumes there is the correct level of signal entering the input sockets of course.
12/31/2023 8:25:12 AM •
Music
Answered
on Dec 31, 2023
