20 Most Recent
Packard Bell Easy One Silver 2101 Notebook Questions & Answers
Laptop back from repair cannot. Connection to
you will have to start up the internet and go to the tool tap at the top and go to internet options and then connections and make sure that never dail a connection is selected. hope this helps
Packardbell notebook can't switch turn on webcam
Look at the keys on your keypad. Do you see one that may have a webcam symbol on it? If so try holding down on the Fn key, and pressing down on that key at the same time.
If this information does not help, then when Windows is loaded, and running, press the Start key, hover your mouse cursor on All Programs, go to the right, hover on >Packard Bell>drop down to >Security and Support>and then Packard Bell InfoCentre.
Click on Packard Bell InfoCentre. On this screen look at the icons across the top. Click on the icon all the way to the right. -> Guides
It has an icon of a book in it.
Look for Webcam.
Easynote r1938 m5306
restart the computer HOLD the keys CTRL+f2 or esc and go to the recover the password and or introuce a new one.God bless you
Packard Bell WiFi Switch on
Kindly check your spec as it doesn't contain built in WiFi however you can add external Wireless card
Good Luck
Laptop runs slow
A slow computer could be caused by a number of things - 1. Insufficient RAM (memory) - if your computer has less than 512Mb of RAM then increase it to at least 1Gb of RAM. 2. Registry problems - clean and repair the registry, it will contain unused registry keys. Use programs such as Registry Mechanic, Microsoft RegClean etc. 3. Uninstall/remove unused programs, this will also free up hard disk space. 4. Not enough hard disk space - swap file space may need to be increased if Windows hasn't been configured to manage it. 5. Install latest Windows updates. 6. Update virus definition files and scan computer for viruses, Trojans, malware etc. 7. Clear the Internet cache for faster browsing. 8. Hard disk maintenance is required at least once a month to keep it functioning efficiently. Run the following programs - Disk Cleanup - removes temporary files that are no longer used and to recovers hard disk space. Disk Defragmenter to make fragmented files into contiguous files and therefore the hard disk access is faster.
Pac Bell Easy Note Sc - boot problems
I think you should remove your Memory RAM at the back of the laptop and wipe the edges with a clean white sheet.you can locate this also using your manual
Put it back and lets notice the results..
But if the problem still exists then i think you should change the memory RAM with a good one..
Please let me get back to me and let me know the results..
Thanks
Won't find wireless connection
Did you turn the wireless switch on? Normally there is a switch either
on the sides or the front of the laptop that you have to turn on.
Sometimes it is a button at the top of the keyboard.
Also once the wireless switch is turned on there are
keystrokes that can toggle the wireless on or off. Normally you would
Press and Hold the FN function key located at the lower left of the keyboard,
then hit the correct F1 thru F12 key that toggles the wireless. The
correct F1 thru F12 key to hit will have the wireless signal icon )))) on it.
Or it might have the icon of a tower with the wireless signal icon )))).
Normally the screen will display Wireless On or Wireless Off when you toggle
the wireless.
Reset my asus laptop to factory settings
It is normally a function key (F1 thru F12) you press repeatedly once
you hit the power button. F11 seems to be the most popular one. Sometimes
the recovery is listed in the program list. Click Start/Programs and
see if you see any reference to recovery. It might be listed in one of
the Asus Folders in the Program List.You can always go to Asus site and download or view the manual. Look for Recovery in it.Get
onlineand got to www.google.com In the google search box type:
"AsusSupport" (without the quotes). Look for downloads and drivers.
Enter your model number and operating system when requested. Look for
Manuals or Documents.
Our cat walked across the key board and now the
Hold the CTRL and ALT key and press the "UP" arrow key on the keyboard.
Thank you
for visiting FixYa! We answer your
concerns promptly for FREE. Please spare a few seconds to
click on YES button and leave a
short comment to let other people know how I help you. Have a good one!
Can t turn on my webcam
Hi
have a look at the top row of keys to see if there is a key with a picture of a camera
if so press it or press FN+ that key or ALT + that key
or
go to control panel find scanners/camera and look for the web cam and press it
o
go to start
all programs
packard bell
user guide/info
and see if that shows you how to activate the web-cam
there are so many makes and models and they can all work in different ways
hope you can sort it
many thanks
Pls hi need free gsm solution
To my knowledge there are no FREE wireless broadband solutions in the country. The least expensive is cricket (http://www.mycricket.com/broadband) which is as low as 40 dollars per month, but coverage is only in certain locations. Your laptop should have a built in wireless adapter which will allow you to access any wireless routers or wifi hotspots. If you have a wireless router at home you can use it to access the internet. If you need further assistance feel free to email me at
[email protected]
