20 Most Recent Gateway ZX4351-47 21.5-Inch All-in-One Desktop (Black) Questions & Answers
My board doesn't recognize all ram
Hi, What is make/model of your board please. Do you know how much ram the board supports. Does you pc have on board graphics or does it use a seperate graphics card
6/2/2015 3:49:12 AM • Gateway... • Answered on Jun 02, 2015
Pc just cuts offf and wont come back on for a while how do i trouble shoot it
You might try cleaning out the inside of the case with some compressed air.Make sure pc is unplugged before doing this. Dust and dirt accumulating inside pc will make it overheat and pc's do not like too much heat buildup.Also, if the thermal grease on the CPU is getting old, the CPU will overheat and that could shut it down. How old is your pc?Realplying New thermal grease onto the Processor will allow heat to transfer off of it better than before.It just sounds to me as a heat related issue.Make sure too that all your fans are operating ok. including the CPU fan.
11/9/2014 2:52:40 PM • Gateway... • Answered on Nov 09, 2014
How do I replace the gateway all-in-one ZX4351 motherboard for other motherboard intel maybe?
if your motherboard looks like the same in the posted link means yes you can change your motherboard with intel motherboard and processor
10/13/2014 4:21:44 AM • Gateway... • Answered on Oct 13, 2014
2answers
I recommend that you try www.youtube.com https://www.youtube.com/watch?v=8KdgEaoe3f8
10/13/2014 4:20:12 AM • Gateway... • Answered on Oct 13, 2014
Pc just cuts off and wont come back on for a day or two how can i trouble shoot it
Easiest thing to do is replace the power supply with a known working unit. An improperly working PS will cause a computer to shut down or simply not work at all.
8/15/2014 9:01:35 PM • Gateway... • Answered on Aug 15, 2014
Pc stays on for a while and just cuts off
The first thing that comes to my mind is it might be overheating. When was the last time you cleaned out the vents on it? Get a can of compressed air at a place like Radio Shack or Office Depot, and work it over, blowing the dust/(cat) hair, etc, out of the cooling vents.
8/15/2014 3:48:43 PM • Gateway... • Answered on Aug 15, 2014
I am having trouble powering up my PC.
You should take a look for a faulty psu
5/24/2014 8:45:01 PM • Gateway... • Answered on May 24, 2014
Will not power up but light flashes
Is there any sound from the hard drive? Any flicker on the screen?
4/7/2014 7:40:03 PM • Gateway... • Answered on Apr 07, 2014
0answers
Where is the fan
There's a CPU fan mounted on the heatsink on top of the CPU and inside case fan(s) mounted in the back of the case.
11/22/2013 9:18:03 AM • Gateway... • Answered on Nov 22, 2013
0answers
Jumper cmos
Be the first to answer 11/16/2013 4:31:39 AM • Gateway... • Posted on Nov 16, 2013Be the first to answer
Why doesn't my computer speakers work. I bought
Which operating system ????..... If your computer came with a motherboard disc the sound drivers could be on it Click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers. Click start control panel sounds and audio volume advanced speakers make sure you have selected the (appropriate speakers) also audio you will find 3 drop down lists make sure you have selected the correct speaker settings. Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it If this does not fix the problem Click start control panel sounds and audio devices you can adjust the volume there also select speaker. volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the speaker volume icon system select adjust volume. Click start control panel sounds and audio volume advanced speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand system speaker right click properties then select use this device (enable). The speaker plug/outlets is usually at the back of the computer or if its a laptop on the side. You will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good with no dust as dust causes static electricity. Clean your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit. Dust causes static to build up in a computer http://download.cnet.com/2000-20_4.html On the home page you should see a search tab just type in what you are looking for. Tick in either the all software or windows software box IE: motherboard name audio driver you might have to try a few times to get it right for windows 7 Click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to update drivers. Click start right click on computer select properties then device manager scroll to sound and video if you right click on sound and video then on high definition audio device select update driver software. Click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers. Right click on the speaker icon in the bottom taskbar you will see an array of options select playback devices make sure it has a green tick and the correct speakers are selected be updated if you computer came with a motherboard disk the drivers could be on it although once speakers are connected widows 7 should automatically update the drivers. Click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker. You might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down list in the advanced tab select dvd quality or another then apply.
10/8/2013 7:15:14 AM • Gateway... • Answered on Oct 08, 2013
My Gateway is not booting up. Itg is
A) Where did the disk come from?Gateway?One you made from the computer? (INTELLIGENT person, if you did!)B) In BIOS Setup, and in Boot Order; do you have the first boot device set to CDROM?C) Is the disk clean? Or does it have fingerprint/smudges/scratches on it?Nothing above works?Suggest the harddrive is bad.Regards,joecoolvette
3/29/2013 1:31:40 AM • Gateway... • Answered on Mar 29, 2013
My gateway ZX4351 is too loud.. How do I open the case and clean the fans?
Depends if the fan's can even be cleaned. There will probably be several screws you will need to remove on the back, along with the stand. The edges may need to be pried open, preferably with a plastic pry bar so you don't damage the case. Once the case is open unscrew the fan and see if it has a rubber stopper in the center, possibly under a sticker. If it does then you can open that and add a drop or two of sewing machine oil and it should be quiet after. If it isn't then I'd just replace the fan.
2/2/2013 7:03:12 AM • Gateway... • Answered on Feb 02, 2013
2answers
Back panel remove gateway zx
There are two plastic covers on the back, one on each hinge of the metal stand that you can pop off. Under each cover are three screws. Remove these screws and set the stand aside. Pull off the two rubber feet on the bottom of the unit. Disconnect the HDMI cable for the display. You can now pry off the back. It's one large piece of plastic. Try to fit a wide flat screwdriver or plastic spudger in the bottom corners of the plastics in the seam where the silver and black portions meet and twist. There are clips that go around the entire inside edge of these plastics so a fair bit of force will be required to get them all off. Using a metal screwdriver is likely going to leave marks so use your fingers or a plastic spudger tool wherever possible. Eventually you'll be able to pry it completely off and you can get access to the internal components (after removing some metal covers held on by more screws)
1/7/2013 2:31:21 AM • Gateway... • Answered on Jan 07, 2013
ZX4351-47 fan to noiser
Get Stealth or silent fans from New egg. Raplace that fan with one of these. Just be sure its the same dimentions
9/20/2012 8:19:35 PM • Gateway... • Answered on Sep 20, 2012
ZX4351-47 fan too noise
Just take it off and order some fans on Newegg. Stealth fans are what you want to look for. Just ensure you get the same size and direct airflow appropriately. I like the neon light ones :)
9/20/2012 8:14:57 PM • Gateway... • Answered on Sep 20, 2012
How do I remove and replace the hard drive in the gateway zx4351
While I have no idea what you mean about the monitor, I can address the HD situation.You must remove it, and set the jumpers to slave, then attach the HD to a working PC of your own, and see whether the data is in tact, or scrambled from the lightning.Cheers!-a.
7/16/2012 2:48:32 PM • Gateway... • Answered on Jul 16, 2012
Speaker stop working on my gateway ZX4351
It's possible that you somehow messed up the audio driver... Go here and download the latest driver and re-install it.... You may want to uninstall the current one first from device manager.Here's the link:http://support.gateway.com/us/en/product/default.aspx?tab=1&modelId=3258
5/15/2012 4:58:30 AM • Gateway... • Answered on May 15, 2012
Gateway ZX4351-47 21.5-Inch All-in-One Desktop (Black) Logo
37 questions posted
Top Gateway Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Gateway Computers & Internet
Most Popular Question
gateway zx4351 loud open case clean
  • Computers & Internet
