20 Most Recent
GE 19GT270 19" TV Questions & Answers
How to install DVD player on GE Model 19GT270 TV
To hook a DVD player to this model, you'll need an RF modulator (also called an RF converter). You can find one at most retailers where they sell TVs, and also online from places like
Amazon.com.
Without the AV jacks, the only way the TV can pick up anything is with its tuner. An RF converter takes the audio and video signals from the DVD player and turns them into a channel 3 or 4 signal that the set can tune in. Unfortunately this does reduce the picture quality some, but on older TV sets it's the only option.
My GE 19GT270 TV turns on fine, runs about 20
These sets are famous for tuner problems. They develop loose connections at certain ground points around the tuner shield and inside the tuner. When the set gets warmed up the solder starts expanding and causing your problem. This can be a tedious repair. You may want to have a shop check it out for you. Thanks for using fixya.
Digital Converter Box
# 1. Why are you using a digital to anaolg box when you only have a analog signal coming in? The box is designed to see digital information then converting it back to analog. Please explain further what you are attemping to do?
Horizonal White Line
Your problem could be one of the common ones as this set has loads of bad solder connections. Your problem is most likly the verticle output IC connections or the B+ feed componets have bad solder connection on them. In some cases though the Output IC is defective and will need to be repalce. if you have no soldid state repair or soldering skills play it safe and get a pro to assist you in this repair. It should not cost you more then a hundred bucks or so and thats the high end. good Luck, And Merry christmas.
Cable input
I think what you what is a 263650 rca rf connector jack. be carefull reinstalling it as it dosent just screw in Follow instuctions Please.
Trying to find model number on my GE universal remote so that I can get codes for my converter box
Locating the model number on a GE universal remote can vary depending on the specific model. Here are some general tips to help you find the model number:
- Check the Battery Compartment:
- Open the battery compartment on the back of the remote.
- Look for a sticker or label inside the compartment that may contain the model number.
- On the Remote's Front or Back:
- Check the front and back of the remote for any labels or markings that might indicate the model number.
- User Manual or Packaging:
- If you have the user manual or the original packaging, check there. The model number is often mentioned on these documents.
- Behind the Battery Cover:
- Remove the battery cover and inspect the area behind it for any labels or markings that include the model number.
- On the Remote's Body:
- Inspect the body of the remote itself. Some models may have the model number printed on the front or sides.
Once you locate the model number, you can then proceed to find the correct codes for your converter box. The codes are usually included in the remote's manual or can be found on the manufacturer's website. If you are unable to find the model number or the manual, you may need to contact GE customer support for assistance.
If you provide more details about your GE universal remote, I might be able to offer more specific guidance.
Need universal remote codes for sansui hdlcdvd265b
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
4 Digit Universal Remote Codes for Sansui TV ; 0394, 5871, 1052 1556, 1208, 0135 ; 0888, 0310, 6071 ; 6061, 0806, 5441 ; 2832, 0264, 1230.
Replacement Remote Control for SANSUI HDLCDVD265 ...
Amazon.com
https://www.amazon.com > Replacement-HDLCDVD2...
This is a custom built replacement remote made by Redi Remote for the SANSUI remote control number 076R0LJ020. *This is NOT an original remote control.
Rating: 4.4 · 12 reviews ·
US$34.95
Replacement Remote for SANSUI HDLCDVD265, ...
Amazon.com
Replacement remote control for Sansui HDLCDVD265, HDLCDVD325B, 076R0LJ020 with
all functions of original one. It replace each button of original remote ...
US$16.00
Need codes FOR GE UNIVERSAL RC 24914-D TO CONNECT MY roku express
Yes, you can use a GE Universal Remote RC24914-D to set up your Roku Express box. To do this, you'll need to find the correct code for your Roku Express device and program it into the remote. Here's how:
- Turn on your Roku Express device.
- Locate the "Code Search" button on your GE Universal Remote. This button is usually labeled "Code Search" or "Setup."
- Press and hold the "Code Search" button until the indicator light turns on.
- Enter the code 9-9-1. The indicator light will blink twice.
- Point the remote at your Roku Express device and press the "Power" button. If the device turns off, you have found the correct code. If it does not turn off, repeat steps 3 to 5 with a different code until you find the correct one.
- Once you have found the correct code, press the "Code Search" button again to save the code.
The codes for the GE Universal Remote RC24914-D can vary depending on the version, so it's possible that the code 9-9-1 may not work for your device. If that's the case, you can try other codes listed in the remote manual or on the GE website.
I hope this helps you set up your Roku Express device using your GE Universal Remote.
