20 Most Recent GE 25GT240 25" TV Questions & Answers
2answers
Am I connecting DVD player wrong?
on some of these older RCA try simply tuning it from the remote down to chanel 01 or 00 this may work. if not you have to go into the setup menu of this set and enable the aux inputs
5/2/2018 12:05:58 AM • GE 25GT240 25"... • Answered on May 02, 2018
TV is connected via coaxial cable to Dish setup. Picture snowy.
This is a classic symptom of a poor signal.
4/21/2017 5:57:19 PM • GE 25GT240 25"... • Answered on Apr 21, 2017
Remote
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device you have. Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its user manual. Never accept a remote control, that hasn't both of this. If you see the site by "MOSAIC" view, will make surf easier. http://electrohelponline.blogspot.com/
3/27/2014 3:48:29 PM • GE 25GT240 25"... • Answered on Mar 27, 2014
0answers
How can I reset my v-chip password? its blocking
1. Hold down MENU on the remote and VOLUME DOWN on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked 2. Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked 3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4. Hold down GO BACK on the remote and MENU on the front of the TV at the same time for at least 4 seconds. 5. Hold down EJECT on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET. If you wish to get more details, check these links. http://electronicshelponline.blogspot.com/ http://electrohelponline.blogspot.com/
10/8/2013 4:09:00 PM • GE 25GT240 25"... • Answered on Oct 08, 2013
manual
Can't get my VCR to work
FIRST!!! Make sure you have the coax or AV cables plugged into jacks marked out on the machine.....then....
*If you have it hooked up with a Coax cable, you should immediately have picture and sound when you turn it on. Make sure you have a dvd/vhs running and switch between channel 3 and 4. if this doesn't work, make sure that you have the cable connected to the one marked 'in' or 'cable in' or 'ant in'. then retry the previous steps.
*If you have it hooked up through A/V cables (Red/Yellow/White), make sure you have them all connected to the same set of jacks. They should be labeled Aux 1 or something similar and are generally surrounded by a box molded into the TV's plastic casing. You will then have to use the TV remote to switch TV/Video settings until you get to the one that matches the Aux jacks you have it plugged into. Again...make sure a dvd or vhs is running and keep flipping until you find a picture.
Hope this helps!!!
8/15/2013 8:42:28 PM • GE 25GT240 25"... • Answered on Aug 15, 2013
Connection of a DVD/VCR player.
I used a Dynex RF Modulator, Model WS-007. Got it at Best Buy.
1/20/2013 8:13:00 PM • GE 25GT240 25"... • Answered on Jan 20, 2013
Can I get higher digital cable channels?
The model indicated here does not have a "digital" tuner so if using an antenna you would need a box for the digital channels---in general non digital sets will not receive digital channels on their own.
12/7/2012 1:29:20 AM • GE 25GT240 25"... • Answered on Dec 07, 2012
Ge tv no sound
Check its speaker first. If it is OK, check and replace damaged component/s in its audio output section circuit inside.
10/13/2012 11:31:57 AM • GE 25GT240 25"... • Answered on Oct 13, 2012
How to reset television to turn back on...
1) reset the c. breaker 2) unplugeed the power cord by 10 minutes. and try again. 3) you can go to the MENU and work by default or to go to the set up from original manufacturer.God bless you
10/12/2012 11:36:36 AM • GE 25GT240 25"... • Answered on Oct 12, 2012
Old TV
I can assume the input for your tv has only a coax input to it. Meaning a threaded connector on the back. If so, first connect the Wii to the input of the dvd player, second, from the output of the dvd player, this is where your solution is needed. run a coax cable from the tv to the DVD player and at the dvd player you will need an adapter from your local Radio Shack or electronics store. It should be a female coax to RCA adapter (male Red White and Yellow).Red and white for audio and yellow for video. Post a pic of the back of the tv if this doesnt solve it for you. Good luck, fingers crossed.
9/7/2012 2:19:00 AM • GE 25GT240 25"... • Answered on Sep 07, 2012
25GT270
Check and replace the faulty component/s at the main power regulator section circuit.
8/27/2012 1:49:05 PM • GE 25GT240 25"... • Answered on Aug 27, 2012
Ge television model 25gt240
Check this link to download it.
8/4/2012 4:04:31 PM • GE 25GT240 25"... • Answered on Aug 04, 2012
Tv shut down replaced burnt fuse but burns again when plug into power supply. what should I do my mom is in her seventies and missing her programs...
i would replace the fuse again and try a different outlet to rule out an electrical problem with that particular outlet. if it blows the fuse in a different outlet it's probably time to retire that TV set it's hard to find anyone to work on them anymore because they've become obsolete due to the flat screens.
7/31/2012 8:10:11 PM • GE 25GT240 25"... • Answered on Jul 31, 2012
GE 25GT240 25" TV Logo
120 questions posted
Top GE Televison & Video Experts
ExpressFiX
ExpressFiX
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • GE Televison & Video
Most Popular Question
remote
  • Televison & Video
