20 Most Recent
Sony FD Trinitron WEGA KD-34XBR2 34" TV Questions & Answers
Blinks 7 times
High
voltage shut-down The high voltage has exceeded 33k and the unit goes
immediately into safety shut-down Check power supply regulation and horizontal
circuits. If you wish to get more details about blinking codes to Sony TVs, and troubleshooting charts, check this link. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by its left side bar,
or view it in Timeslide option.
7/3/2013 8:14:50 AM •
Sony FD...
Answered
on Jul 03, 2013
SONY TRINITON KV-32XBR15
The picture has
From your description it sounds like a yoke problem, you describe an hour glass picture which is a classic symptom of the horizontal sector of the yoke is at fault. The easiest way to test for this is a ringer tester, chances are it will show a short in the horizontal winding which causes the high voltage to load down and draw more current in the process.
3/14/2011 6:22:28 AM •
Sony FD...
Answered
on Mar 14, 2011
The left hand edge of
That picture tube may be sensitive to nearby magnetic fields. If you have external speakers, move them a little further from the set. another possible fix is the degauss option in the menu. Very well rated set, I hope this helps:)
8/20/2010 3:07:46 AM •
Sony FD...
Answered
on Aug 20, 2010
Sony TV
TV in A1 condition with stand / table worth for $200 and seems OK.
3/25/2009 1:03:39 AM •
Sony FD...
Answered
on Mar 25, 2009
Ilink Menu continuosly popping up
Maybe. It appears that there may be a bad connection. Probably a bad solder joint. The problem started after I moved the TV. Today I was a little frustrated and jarred the TV pretty good while moving it. The problem went away and hopefully will not return. When and if it does I guess I'll have to check internally for a bad connection.
12/31/2008 7:51:41 PM •
Sony FD...
Answered
on Dec 31, 2008
Sony Trinitron KV-32XBR15
You should check Pin-Amp stage for subject problem. Pin Amp is located at Horizontal area. Pin Out Transistor is suspected.
6/8/2008 2:33:20 PM •
Sony FD...
Answered
on Jun 08, 2008
KD-34XBR2 calibration
Well most of the time you are not going to want to get into the service menu of any tv, unless you know what you are adjusting and actually have the required test equipment. Most of the time you can get away with putting in a dvd that has the THX optimizer and adjusting the normal user settings that way. A dvd with the THX optimizer is Indiana Jones. Hope this helps.
5/11/2008 2:56:28 AM •
Sony FD...
Answered
on May 11, 2008
Tv maintenance
Yes it is wise to vacuum the dust of your tv at the back. What i do once a year is open the tv ( after your warranty period runs out) and blow the tv out completely in order to keep the prints free from dust
5/9/2008 8:50:17 PM •
Sony FD...
Answered
on May 09, 2008
