RE: software installation problem
Right now I am going to go backwards----
Memory Card, when you put the card in the camera, you need to format it. With most cameras, you go to the Menu, scroll through the menu and find memory card, format, click on it and the camera will format the card for the camera.
Once formatted, you set the camera to use the memory card, also in the camera.
Now all pictures will go to the memory card.
If you have a computer with a memory card reader, you put the card in the slot on the computer and the computer will recognize it. Go to Start---Computer---double click on the memory card---your pictures should show up. Usually with Vista you will get a box that pops up after inserting the card that asks you want you want to do. Such as view files, transfer pics to a certain folder etc.
***Make sure you are using a memory card that is compatible with the camera. This does not seem to be a newer model so an SDHC card probably will not be compatible. An SD card would be. If we cannot find a drive don't fret, using a memory card you do not need the driver for the camera.
Do you have the disk? I have gone to ApexDigital website, and cannot find any drivers for the camera. They show the camera, but no downloads. I will keep hunting for you but in the meantime:
On the camera there should be a serial number, look on the bottom of the camera, if you can find one, give me all the numbers you find. I will go from there.
Don't give up yet!
