Tip & How-To about Cameras
How to easily download Pictures from Digital Camera
Many people are having trouble downloading the digital pictures that they take on their digital cameras to their computer. This can be a very simple procedure by doing things just a bit differently then most of the digital camera instructions tell you to do it.
I seems that every digital camera manufacturer wants you to download your pictures by hooking the digital camera to the computer through some type of a wire. While this will work for many cases, the digital camera then also causes your computer to download or have you install other drivers that can be unstable and load your computer up with more stuff, that just causes it to run slower. There is a very simple way to avoid all of the problems and very easily download your pictures.
The first thing that you need to do is to find out what type of media card your camera saves the digital images on. Some cameras use a media card or stick that is brand specific, but many digital cameras are now using a simple SD Card to store the pictures on. No matter what form your camera uses there are card readers that can read the card without it being in the digital camera. By removing this card and installing it directly into a card reader in your computer you can easily access the pictures without all of the other problems.
Many newer computers are installing a number of different card readers directly into the computer. If you have the correct reader installed in your computer already then just insert the card into the reader and then if the card does not show up, just look for it in your start menu under "computer". It will be visible under the "removable storage" devices in the menu.
If you do not have a card reader installed in your computer, you are still okay. You can purchase a card reader for your specific card easily. They are readily available and do not cost very much. I use an SD Card reader that looks like this.
I also use a separate USB Adapter so that I can plug many USB devices into my computer even though I do not have enough USB Ports in my computer to handle all of them at one time. Do not worry, the computer will still recognize them all and you can still access them all easily.
Once you have the card reader plugged into your computer, then just insert the card into the USB card reader and then go to your computers start menu. Find the "computer" and click on it. Then find the card reader under "removable storage devices" and click on it. Then follow through clicking on the prompts till you start to see you pictures being loaded. You can then just delete, copy or move the pictures just as you would any other file on your computer.
One last thing to remember. If you are having trouble accessing the digital pictures or removing them from the card, make sure that the card is not "locked". If you look closely at this picture, you can see the word "lock" and an arrow. If the little tab on the side of the card gets pushed towards the "lock" position you will not be able to do anything with the digital pictures on the card. Move the tab to the forward position "unlocked" and you will be able to do what you want to do.
This will give you an easier way to download your digital pictures without all of the problems that the camera drivers will give you. You will eliminate many potential problem spots by doing it this way and it will work just as well for you!
How to Unlock SD Card
Digital Camera Manuals, Drivers, Downloads, and Support
Cameras Logo
I am having trouble downloading pictures from camera to vivitar experience can you help?
Try NOT connecting the camera to the computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use Vivitar Experience, or any other photo cataloging program.
May 21, 2010 | Vivitar ViviCam 8025 Digital Camera
sony dsc
please visit (sony-mea.com) & down lode the require soft ware
Apr 25, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
I am having major trouble uploading all my pictures from my sony camera into my computer, it keeps stopping at 30 pictures and doesnt upload the rest fo the pictures?? what could be wrong
It could be an error on the 31st picture. Try accessing the camera thru My Computer and download the pictures by dragging them to a folder on the desktop. If that also fails, try skipping the 31st picture and download from 32nd onwards. When successfully downloaded, the card should be formatted in the camera.
Apr 13, 2010 | Sony DSC-S930 Digital Camera
Hi--my pictures wont download to computer--gets to
Check your firewall settings on the computer your having trouble with.
Dec 07, 2009 | Ricoh Caplio R7 Digital Camera
camera trouble
Here is the driver from Polaroid's website for your camera. i633 Driver It should allow you to download pictures from your camera.
Also, incase you need it, here's a link for the user manual. User Guide (English) It should describe in greater detail how to download your pictures.
Mar 09, 2009 | Polaroid i830 Digital Camera
7,789 people viewed this tip
Top Cameras Experts
Ekse
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
