20 Most Recent Haier HTF24R21 24" TV Questions & Answers
2answers
Blue Screen
Turn it off at the wall too and disconnect then turn it back on it may reset itself
1/3/2017 10:09:06 PM • Haier HTF24R21... • Answered on Jan 03, 2017
How touse the DVD on my TV?
My tv problem is vertical section Haier tv model no 21f19ss
11/22/2013 10:46:30 AM • Haier HTF24R21... • Answered on Nov 22, 2013
Haier 21f19ss service code
vertical problem
11/22/2013 10:44:15 AM • Haier HTF24R21... • Answered on Nov 22, 2013
2answers
Haier tv stuck in standby mode, led red on.no control on remote?
bad memory ic in the main board.
8/5/2013 8:46:45 AM • Haier HTF24R21... • Answered on Aug 05, 2013
Using the DVD player
contact with the retailer
6/5/2013 7:11:43 AM • Haier HTF24R21... • Answered on Jun 05, 2013
No remote
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 750 posts to different brand TVs now.
9/16/2012 12:49:37 PM • Haier HTF24R21... • Answered on Sep 16, 2012
Universal remote
Four digit codes for Haier TV are: 0081 0216 0217 0157
9/16/2012 12:48:19 PM • Haier HTF24R21... • Answered on Sep 16, 2012
0answers
2answers
Rings on outside edge of
Hello
Your TVs Degausing coil is not working. Degausing coil is one, which fitted around the picture tube internally, to demagnatize it at each time you switch on the tv. if you are using your TV without switching it off by its mains switch, and turn it to an other direction, this effect will occcur. You just switch off the TV by its main switch, and leave it for about 1/2 an hour, and then switch it on, and see whether it helps or not.
If not, the degausing posistor inside fitted on the circuit board of the TV, has to be replaced. It can be located on the power supply input section of your TVs circuit board. Ok.
11/23/2010 2:19:31 PM • Haier HTF24R21... • Answered on Nov 23, 2010
I can not hear any Audio
the sound IC is bad, that' why you cannot hear any audio from your TV.
You need to change the sound IC to hear audio from your TV again.
Good luck
10/11/2010 5:27:16 AM • Haier HTF24R21... • Answered on Oct 11, 2010
I rolled on remote and it somehow it locked the tv
There should be a button on the remote with the same lock symbol, press it.
10/16/2009 11:38:13 PM • Haier HTF24R21... • Answered on Oct 16, 2009
Exiting service mode (i think)
if you have pp button on remote press it.or try with main sitch
8/26/2009 1:26:53 PM • Haier HTF24R21... • Answered on Aug 26, 2009
Haier HTF24R21 24" TV Logo
36 questions posted
Top Haier Televison & Video Experts
Paul Bade
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Haier Televison & Video
Most Popular Question
blue screen
  • Televison & Video
