20 Most Recent
Haier HLT71 7 in. Portable TV Questions & Answers
Is there any way to add more channels or delete
Haier HLT71 is a digital TV, that meanthis tv can recive digital broadcast.
A digital tv have 8 program each channel. Not like analog tv that only 1 program each channel.
So, if you want to save 1 channel , 8 channel will automaticaly saved as well.
Thats imposible to save or delete from your program.
WHAT IS THE PORT UNDER
This is a
Star Trek GNDN USB mini port for the Haier factory to update the firmware (software stored permanently) in the TV.
If you return the set to Haier for servicing under the 90 days labor, 1 year parts warranty, Haier will probably just send you a refurbished unit.
Part of the refurbishment is for the Haier factory to update the software which runs this digital TV.
If you connect your computer to the port with the correct cable, nothing will happen.
No drivers or user mods (hacks) appear to be available.
I see a no data base what can i do
It says no data base because it has not found any channels that are acceptable.Not all areas of the country or the world would have the same base of channels so that is why it has none when first used.It needs to scan the air waves to build the data base for its current location,if you were to move or take the HLT71 on a trip you would have to do this again. Also unless you live in a highly populated area you will need to use an outdoor hdtv antenna as the antenna that comes with it is not powerful enough.The TV is great but the digital technology used for broadcasting is just not that good yet. You can also hook it up to cable or satellite. Good luck and I hope this helped.
I am receiving a no
It says no data base because it has not found any channels that are acceptable.Not all areas of the country or the world would have the same base of channels so that is why it has none when first used.It needs to scan the air waves to build the data base for its current location,if you were to move or take the HLT71 on a trip you would have to do this again. Also unless you live in a highly populated area you will need to use an outdoor hdtv antenna as the that comes with it is not powerful enough.The TV is great but the digital technology used for broadcasting is just not that good yet. Good luck and I hope this helped.
I need a antenna that have a good strength to get
Tries websites like Amazon.com,Ebay.com to buy a Digital design antenna for a better strength longer ranges.But many of these antennas are design for mostly big tvs sit on a table tops.Just look for many of those digital design antenna choices,one of them will be snall enough and portable enough to carry with ur portable tv.
