20 Most Recent Olympus Camedia C-830L Digital Camera Questions & Answers
The camera will not accept power either from batteries or power cord?
Recycle the camera. WWW.BAN.ORG
4/2/2015 10:29:46 PM • Olympus Camedia... • Answered on Apr 02, 2015
What lead do i need to down load to my pc
Hi - That camera is pretty old and was before the wide use of USB cables. It uses a proprietary serial (RS-232C) cable that would be hard to find (none on ebay - I checked) and if found might cost more than the camera is worth.
Regards, Mikeywaf
2/28/2011 8:50:10 PM • Olympus Camedia... • Answered on Feb 28, 2011
My laptop refuses to accept that there is a camera
Time to start using a separate card reader.
4/14/2010 8:37:49 PM • Olympus Camedia... • Answered on Apr 14, 2010
IS THERE A LEAD THAT WILL FIT INTO A MODERN LAPTOP
Get a USB adapter, that is the easiest solution...
2/3/2010 4:26:38 PM • Olympus Camedia... • Answered on Feb 03, 2010
For formating card
Try http://lclane2.atspace.com/olformat.html
The Olympus C-830L camera is the same as the D-340R
4/12/2009 9:32:18 PM • Olympus Camedia... • Answered on Apr 12, 2009
Olympus digital camera c-830L driver for windows xp
Either use a Smartmedia reader, or download the D-340R driver (twain31.exe) from the Olympus America site.
The C-380L is the same camera as the D-340R
4/12/2009 9:31:09 PM • Olympus Camedia... • Answered on Apr 12, 2009
2answers
I do not know how to use
Full user guide available for download at:
http://www.ipix.com/downloads/olympuscameras.pdf
Hope this helps and your rating would be appreciated thanks.
4/12/2009 9:29:54 PM • Olympus Camedia... • Answered on Apr 12, 2009
Olympus camedia C-830L.
Hello
Problem formating smartmedia memory card olympus c-830 l . Model card M-8P D3V20 , 8 Mb.
No user manual c-830 L , no guide for formating .
My format card for pc - fat 32 and desastre .
Please , information for formating card .
Sorry , no speek english .
My adress :
Nicolae Grozav
Loc. Arbore nr. 769
Jud. Suceava - region Suceava
Cod - zip 727015
ROMANIA
Tel. +40 0230/539336 or +40 0742/551259 - mobile
email : [email protected]
Yours sincerely , Nicolae Grozav
3/27/2008 4:12:25 PM • Olympus Camedia... • Answered on Mar 27, 2008
2answers
How do I transfer my pictures from my Olympus C-220 Zoom camera to my PC?
Yes, there are two ways 1. Connect the camera via USB, and look in File Explorer or 2. Take on the Media Storage Card and put it into a Card Reader attached to the computer. https://www.manualslib.com/manual/301217/Olympus-Camedia-C-2-Zoom.html?page=31#manual ..
3/27/2024 9:57:45 PM • Olympus Camedia... • Answered on Mar 27, 2024
2answers
Olympus Camedia E10 won't power on with AA NI-MH batteries but works fine with AA ALKALINE, what can I do?
Always charge batteries before using it for the first time, or if you have not used it for a long period. 3 months is a very long period. Always charge sets of batteries (2 or 4) together. Make sure your rechargeable batteries are all good. One defect in a set is killing for the whole set Don't use barrettes from different sets or brands together. I had one brand good NiMH batteries and a very expensive charger from the same brand. The charger destroyed all my rechargeable (more than 60 now). When I first discovered the batteries were dropping out, I stopped using the charger, but it did not prevent all batteries to die in the following months. Every time on dropped out I had to change the set. I tried using up the others by grouping the ones with the same Ri, but not longer then a few months and I had a box full to trow away. Never use a quick charger, capable of charging them within an hour or faster. Us a charger that indicates the Ri is still low enough, so you can see what batteries are bad. Check you are using a charger for NiMH batteries. I would try another set (new) because buying Alkaline is also not cheap. I used 2700 mAh and later 2600 mAh rechargeable, all dead now. since a few weeks I'm now using 2300 mHh from another brand, costing 1/5 of the "best" I had before, and they are doing great. I won't charge them with the quick charger. Never use manganese (Zinc-Carbon) batteries in electronic devices. These batteries are only to be used in flash lights.
12/7/2016 8:12:01 AM • Olympus Camedia... • Answered on Dec 07, 2016
How to use zoom on c-860L
This 14 year old camera, does not have a zoom lens. It has a 5,5 mm lens, giving it a angle of view of about a 35 mm lens of a Full frame camera. However, you should be able to zoom digital 2 times. I can't find a manual, to help you on this, but the quality will be the same as cropping into a frame on your computer. So if you do put the pictures on a computer, you also can "zoom" in to the parts you want. Be aware a 1 megapixel camera, does not offer that much of detail.
10/27/2014 11:34:04 AM • Olympus Camedia... • Answered on Oct 27, 2014
Zoom error olympus
Lens is out of possition and stuck.
7/31/2014 7:19:31 PM • Olympus Camedia... • Answered on Jul 31, 2014
Camedia e20 problems
Put memory card into camera right way around.
7/5/2014 6:38:40 PM • Olympus Camedia... • Answered on Jul 05, 2014
Camedia e20 wont record picture
Hi, any error messages?
6/20/2014 1:31:49 AM • Olympus Camedia... • Answered on Jun 20, 2014
0answers
Manual setting of focus
Like many point&shoot cameras, the SZ-12 does not have manual focus. The closest you can come is to point the camera at the object your want in focus, press the shutter release button halfway, then frame the photo the way you want it and press the shutter release button the rest of the way.
12/16/2013 4:24:41 PM • Olympus Camedia... • Answered on Dec 16, 2013
Olympus Camedia C-830L Digital Camera Logo
10 questions posted
Top Olympus Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an Olympus Camera Expert? Answer questions, earn points and help others
View Most Popular
Camedia Olympus
  • Camedia Olympus
Most Popular Question
lead need down load pc
  • Cameras
