20 Most Recent
Aiwa CDC-X217R CD Player Questions & Answers
CD Player not working
There may be dust inside the unit on the laser. Try shoting some compressed air in the CD drive area to clean out. Also, ensure that the CD surface is clean, and try a different factory made audio CD. Sometimes CD players have problems reading "burned" CD's.
What color wires go where
To find out what your factory wires on your vehicle are, go to installer.com then click on the tab, cables and wires, select your vehicle.
What I do is go to walmart, kmart, target or similar, and get the $5 connector.. It wires to cd player and just plugs into the factory plugins.
Cd player wiring-
Yellow - Direct 12 volt power from battery - keeps memory and channel presets
Red - Wire from ignition to turn on
Black - Ground wire - best to attach to unpainted body metal
Orange - Dimmer - Not used
Blue - Not used unless you have power/electric antenna
Blue with white stripe - Not used unless running an amplifier, then it attaches to rem on amp
Gray - Right Front Positive
Gray/Black Right Front Negative
Purple - Right Rear Positive
Purple/Black - Right Rear Negative
White - Left Front Positive
White/Black - Left Front Negative
Green - Left Rear Positive
Green/Black - Left Rear Negative
Help
Yellow - +12V Constant Power
Red - +12V Switched (accessory) Power
Blue - Power Antenna
Blue/White - Amp Turn-on
White - Left Front Positive Speaker Wire (LF+)
White/Black - (LF-)
Gray - Right Front Positive Speaker Wire (RF+)
Gray/Black - (RF-)
Green - Right Rear Positive Speaker Wire (RR+)
Green/Black - (RR-)
Purple - Left Rear Positive Speaker Wire (LR+)
Purple/Black - (LR-)
