20 Most Recent
Aiwa CDC-X504MP CD Player Questions & Answers
While driving and listening to
My daughter had same issue with her Aiwa car radio. removing and replacing the radio power fuse made it happy and it has been so for nearly a year.
Stuck in demo
I had the same issue and was about to give up.
cleaning, key combos and such didn't work out.
Solved the dirty way, as described some comments above:
"Just took the faceplate from the "push-menu" button and hit it against
a hard surface [not too hard but not too soft hits] and thats it, it
worked again."
ah, the good manners!
I have a CDC-X504MP. How
To get to the sound settings:
Press and hold the Volume knob down.
Press the "Seek" button until you see "Fad" on the display
It will be between "Bal" and "LPF"
Turn the volume knob to adjust
The automatic CD feeder isn't
This is an internal problem that will need servicing/parts.
You may find the repair bill, however, to be more than the cost of a new unit.
It is likely a servo motor or internal limit sensor has failed on the cd carrige.
Thanks!!
Cd will not eject
you can try disconnecting power to the stereo for a few minutes. sometimes the reset switch doesn't always completely clear the memory of the uprocessor.
All power and grounds work cd player si not coming
on the amp try gettin a different wire connecting the power stright to the remote useing a different wire touch both of them . and see if the power comes on i had the same problem and i tryed that and it worked .
Aiwa CDC-X504Mp stuck in demo mode
This recently happened to my Sony, maybe it will help u
If this cd player has a removal fascia then try..
Carefully inspect the the electrical contacts on the fasica and the cd player. If it has got dirt on them then CAREFULLY CAREFULLY clean with cotton swab dabbed in cleaning Alcohol.
