20 Most Recent
Alpine CDM-7861 CD Player Questions & Answers
How to operate Alpine CDM 7861R
You could download the manual from :-
http://safemanuals.com/user-guide-instructions-owner-manual/ALPINE/CDM-7861R-_EYou need to click on ' Download the complete user guide '. Once clicked, it would direct you to a new page.Rate those 5 questions on a scale of 1 - 10. Once done, Download the user guide links appears. Click that and you would see a pop up. Save the file on desktop. You need to have acrobat reader to view the file.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Can not preset radio stations, how do i do this
Find the desired station, press and hold the desired preset key and wait for it to blink and acknolwdge you and repeat steps for all desired presets, if not read the manual or go to a local car audio shop and they can help you.
Good luck.
* Please rate and vote for me if I helped. thanks.
Just connected a CDM 7861
Initial System Start-Up
Immediately after installing or applying power to the
unit, it should be initialized. Press the RESET button
at right corner of the front panel.
I dont ehere the cd goes
Press the eject button (lower right corner) and the face plate will drop down, showing a cd slot.
Alpine cdm 7861 stuck in pause mode
Check for a "jammed" button. They use a little rubber membrane behind buttons and over time they do wear out. It is possible to push a button on the corner, make it shift enough to jam behind the faceplate & hard to see. Just push the button and see if it pops back like the rest of the buttons on the unit. If it still has a problem, post a comment and I will help you some more. Hope this helps
How do I set the time?
Setting Time
1 While the clock time is displayed, press and hold
the CLK (clock) button for at least 3 seconds.
The time indication will begin to blink.
2 Press the CT button while the time indication is
blinking to set seconds to "0".
3 Press the "H" button to adjust the hours while the
time indication is blinking.
4 Press the "M" button to adjust the minutes while
the time indication is blinking.
The time indication will stop blinking 5 seconds
after the last adjustment. The time will
automatically be set.
Setting time
- While the clock time is displayed, press and hold the CLK (clock) button for at least 3 seconds. The time indication will begin to blink.
- Press the CT button while the time indication is blinking to set seconds to "0".
- Press the "H" button to adjust the hours while the time indication is blinking.
- Press the "M" button to adjust the minutes while the time indication is blinking. The time indication will stop blinking 5 seconds after the last adjustment. The time will automatically be set.
"error" message when playing cds
Same problem here. It was every now and then it would happen but now its constantly. It aggravates me and I'm gonna have to buy a new deck because I don't know whats wrong
Cdm alpine 7861
Make Sure the remote wire is connected from the radio to the amp, its normally a blue wire. Here is a picture of what the setup should look like.
CDM 7859RB
clean the contacts of the connections if that does not work it is time to call a tech or replace the face plate could be faulty.good luck.
