20 Most Recent Alpine CDA-9856 CD Player Questions & Answers
0answers
0answers
I pod says no songs on 9884 modle
Your iPod is not compatible with the radio.
12/29/2013 9:55:14 PM • Alpine CDA-9856... • Answered on Dec 29, 2013
0answers
Iphone mode
For most alpine unit there is a separate unit to control the iPhone and is very easy is just a plug and play connection. Find a compatible unit for your deck.
11/8/2013 3:59:44 AM • Alpine CDA-9856... • Answered on Nov 08, 2013
manual
2answers
Radio sound but NO cd or ipod sound
Radio is screwed.
But try these these steps:
Clean the eye of the head for reading CD. Must open up the radio.
IPod: check for good connections from Ipod to PCB.
7/9/2013 9:23:12 PM • Alpine CDA-9856... • Answered on Jul 09, 2013
Radio and CD is on but no sound. all amenities show good.
have it hooked up right on the system? are all wires good?
3/12/2013 12:26:21 AM • Alpine CDA-9856... • Answered on Mar 12, 2013
I just replaced the alternator on my vehicle and now the cd wont turn on everything esle in the car works fine
Check all of the fuses in your vehicle. There are probably two fuse boxes in the car. One in the engine compartment and another inside of the car either under the dash or in a kick panel. If you can check the wire harness behind the deck. There may also be a fuse in the back of the deck.
1/28/2013 7:27:32 PM • Alpine CDA-9856... • Answered on Jan 28, 2013
Hi there I have alpine cda 9856 cd player and it turns on and does every normal however it won't output and sound on either radio or cd. I have checked for any bad connections and can't seem t
Did you make sure you have no shorted or grounded speakers or speaker wires? Make sure you don't have a bad speaker also. If everything checks out, you may have a bad internal output ic.
1/16/2013 5:36:17 PM • Alpine CDA-9856... • Answered on Jan 16, 2013
How to set the clock
Press the Title button (to the right of the display) until the time is displayed. Press and hold the Title button until the time starts to blink (2+ seconds). Then turn the rotary encoder (the center circle of the set of buttons and controls on the left of the display) to set the current hour. Press the Mode button (below the rotary encoder). Then turn the rotary encoder to set the current minute. Press Title to exit the Time Set mode (or the unit will exit the mode if no buttons or controls are moved for 5 seconds). Alpine USA has the Owner's Manual for the CDA-9856 here: vault.alpine-usa.com/products/documents/OM%20CDA-9856.PDF . See page 7 (page 9 of the PDF) of the manual.I hope this helps. Cindy Wells
11/30/2012 11:38:32 PM • Alpine CDA-9856... • Answered on Nov 30, 2012
2answers
I love loud music
i have alpine stereo's in all my vehicles and i have had this problem. if you run a 10-14 gauge constant wire from the stereo directly to the battery the stereo will not shut down in protection mode. it is not the cd it is the stereo going into protection mode because of lack of current not voltage. i hope this helps after i did this i could play the stereo as loud as it can go until my battery died
2/17/2012 12:25:46 AM • Alpine CDA-9856... • Answered on Feb 17, 2012
2answers
How to set clock for CDA9856
1 Press TITLE repeatedly until the time is displayed.
2 Press and hold TITLE for at least 2 seconds while the time is displayed. The time indication will blink.
3 Turn the Rotary encoder to adjust the hours while the time indication is blinking.
4 When the hour has been adjusted, press MODE.
5 Turn the Rotary encoder to adjust the minutes while the time indication is blinking. The time is automatically set 5 seconds after the minute adjustment. The time can also be manually set by pressing TITLE.
This is from page 7 of the user's manual, available here.
If this helps, please be sure to hit the "thumbs up" for me!
1/26/2012 11:38:58 PM • Alpine CDA-9856... • Answered on Jan 26, 2012
Alpine CDA-9856 CD Player Logo
90 questions posted
Top Alpine Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Steve Sweetleaf
Steve Sweetleaf
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Alpine Car Audio & Video
Most Popular Question
love loud music
  • Car Audio & Video
