20 Most Recent
Apex Digital GT2015DV 20 in. TV/DVD Combo Questions & Answers
My apex tv is stuck on zoom, how do i fix it?
HelloMake a factory reset to this set. I assumes that you have its remote control wih you now, and posts this solution. If you did forget the parential pass code, just enter '6688' when the set asks for passcode. The previous set passcode will clear out, you ahve to set a new passocde in place. After resettign the pascode, just make a factory reset to the set, by entering into it menu option.Without remote control, you can't do anything with this set. If you lost its remote control, you can buy it directly from Apex Digital. The price ofr the remote control in US or Canda is $35. In this case, please contactAPEX DIGITAL,INC,Customer service: 2119E, Philadelphia, Ontario, CA91761866-4APEXINC.website: www.apexdigitalinc.comOK
Apex tv locked
If you have a blank screen with a red key on the bottom left, simply
press the (function or F) button and the mute button at the same time.
If your TV asks for a 4-digit code or password please enter 3308 or 6688 to unlock the screen or reset any preset rating levels.
If you have a GT2011J or GT2011S Television, hold the (Display) button
for 10 seconds, it will unlock the screen. If password or code is
requested, try 3308 or 6688.
Let me know if this helps.
I have a Apex TV/DVD
Hi tweetybirdfa,
Original remote control is no longer available but I have a link for the substitute one.
Click this
LINK.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Jdvillanueva
My dvd drive is stuck
If it has been overloaded with too many dvd's, then you won't be able to eject them. You'll have to disassemble and remove the discs manually, if you are not comfortable doing this, call an electronics shop, most large ones (FutureShop, BestBuy) will preform repairs. Cheers!
How do I remove the parental code if I dont know
Hello
Apex TVs use a four digit code to control the v-chip. The override code for many models is 6688. Other sets may not have one, or may have a default code of 1225 instead of an override code.
- To use the override code:
- Hit the MENU key to get to the menus.
- Go down to the SYSTEM menu and hit the right arrow on the remote control.
- Once in the SYSTEM menu, go to PARENTAL GUIDE. It will ask for your code.
- Enter the override code listed above. From here, you can turn on and off different rating restrictions, as well as set a new code.
No matter what the V-chip code is set to, the override code will still work. If you have a blank screen with a red key on the bottom left, simply press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired
The t.v. will not play anything
Someone has invoked the child lock. Check your manual to see how to unlock this . Sometimes this info is on a sticker applied inside the manual or instructions for use.
Please rate my help++++Thanks for using FIXYA
