20 Most Recent
Apex Digital AT3208S 32" TV Questions & Answers
Apex troubleshooting
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience.
Pull up older posts.
Loss of Picture on Right and left side
Take your remote control, press volume to 0
Press the mute button on your remote, at the same time, press the menu button on your TV for 3 seconds.
A menu will apear, press the right arrow on your remote to go to menu 002 to fix your problem.
[email protected]
Picture size
Visit
this site for more details. Your problem post is not clear; no details to provide a solution.
The volume on our model AT1302 (32") keep going up
Hello
There is some loose soldeings in the audio output section of your Apex TV. It is quite common for this model with this fault. Resolder all the susepected soldering points in the audio output section of your TV, by applying a little more solder to each point, without making any solder bridge short in between adjcecent solder terminals. This will solve the problem of your TV. OK.
Blue Screen of Death???
I have same problem, screen is blue for cable TV, same for DVD and for the S-video imput. The menues works good for adjust the color or the TV lenguages, but I can see only the blue screen.
Sound no picture
Check your video cables and ensure they are wired properly. With no information you are not going to get any better of an answer.
Apex tv
should be inside the back cover on the left hand side toward the rear of the television
