20 Most Recent
Sharp (BQCXGC50X1) Projector Lamp for PG-C45X, PG-C45S, XG-C50 Questions & Answers
Does anyone have a diagram describing the location
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
9/28/2016 7:47:32 AM •
Sharp...
Answered
on Sep 28, 2016
XG-C50
pls check the fans under the Optical Engine, under the prism
the fans easy to be failed
Have a nice day!
Jerry
Lampdeng Limited
8/26/2016 8:05:28 AM •
Sharp...
Answered
on Aug 26, 2016
Sharp XG-C50X Notevision. Doesn't get past "warming up"
it seems that the powersupply is failed
Have a nice day!
Jerry
Lampdeng Limited
8/26/2016 4:17:20 AM •
Sharp...
Answered
on Aug 26, 2016
PG-C45X projector wont power on
To solve this problem, simultaneously press the "Input", "Enter", and "Undo" buttons. While holding these buttons, press "On". When the project turns on, you should see "LAMP 100%". This indicates that you have successfully reset the lamp life timer.
6/6/2009 2:36:57 AM •
Sharp...
Answered
on Jun 06, 2009
XG-C50 Problem
Hello
Replace the fly-eye lens of projector.
Viren
2/6/2008 12:20:14 PM •
Sharp...
Answered
on Feb 06, 2008
System lock of my projector sharp 50s ,so how to unlock?
- Check the Remote: Make sure you have the remote control for the projector.
- Press the Menu Button: On the remote, press the "Menu" button.
- Navigate to Security or System Lock: Use the arrow keys on the remote to navigate through the menu options. Look for a section related to "Security" or "System Lock."
- Enter the Unlock Code: If you previously set a system lock code, you will need to enter it using the remote control. If you haven't set a code before, try the default code (often 0000 or 1234).
- Disable System Lock: Once you've entered the correct code, navigate to the option to disable or unlock the system lock.
- Confirm: Follow the on-screen instructions to confirm your choice, and the system lock should be disabled.
Sharp EL-1197PIII printing nonsense after a jam.
Reset the calculator: Locate the reset button on the bottom or in the battery compartment and press it .
Clean the printer head: Use a soft, dry cloth to clean the printer head and ensure that there is no debris or paper stuck in the printer mechanism .
you are looking for resources to properly align the gears. I found a few resources that might be helpful:
Sharp EL-1197PIII Operation Manual: This manual provides detailed instructions on how to operate and maintain your calculator, including how to align the gears. You can download the manual from the following link:
SHARP EL-1197PIII OPERATION MANUAL Pdf Download ' ManualsLib.
Sharp EL-1197PIII User Manual: This manual also provides instructions on how to align the gears of your calculator. You can access the manual online from the following link:
Sharp EL-1197PIII User Manual online (mans.io).
Sharp EL1197PIII Heavy Duty Color Printing Calculator User Manual: This manual provides instructions on how to align the gears of your calculator. You can download the manual from the following link:
User Manual Sharp EL1197PIII Heavy Duty Color Printing Calc ' manualsFile.
