20 Most Recent
JVC TH-A5 System Questions & Answers
Controll panel says lock
Try unplugging the unit from power for 10 minutes then plugging back in to try to reset the system. If this does not solve it you may have a faulty ejection circuit in the unit, when the circuit is activated it locks the system.
Have run a Memorex lens
Ok this is simple you need to replace your laser pickup. This is the laser that reads your CD. When it is defective you can clean it all you want but it will not read your CD or DVD. You will have to let a tech do this unless you are a tech yourself thanks.
Thanks.
Tray door won't open
Sounds like the cd is jammed. Look for a small hole you can poke a paper clip in. This manually opens the tray. If that doesn't work you may have to pry GENTLY on it. Just help it to catch a gear to get your cd out. Then check the operation to see if it was a one time occurance. If not, you may have to buy another one. It's cheaper than getting it fixed.
System not functioning
If the radio or the other functions dont work, then theres a system control problem or a power supply problem. Depending on nhow old this unit is, you may want to consider upgrading as this unit will have to go into a repair shop to trouble shoot. If you have had some solid state training or experience, and have a schematic and a multi meter its a good possibility you can find the problem.. Good Luck
Problem with original dvd
Before performing any operations, make sure of the following:
? Check the connection with the TV.
? Turn on the TV and select the correct input on the TV to view the pictures or on-screen indications on the TV screen.
? For DVD playback, you can change the Setup menu setting to your preference menu...
Alos, make sure thay the system and disc region code numbers are incompatible:
The following discs cannot be played back: ? DVD-Audio, DVD-ROM, DVD-RAM, DVD-R, DVD-RW, CD-ROM, CD-I, (CD-I Ready), Photo CD, etc. Playing back these discs will generate noise and damage the speakers.
* Note on Region Code DVD players and DVD Video discs have their own Region Code numbers. This system can play back DVD discs recorded with the color system of NTSC and PAL whose Region Code numbers include ?3.?
Loud Poping sound
It sounds Like your power supply has developed a fault, advise not to use/or turn on untill problem is sorted
I have a JVC RX-501 reciver and 2 speakers Sony(200W). I start the reciver and After 3-4 seconds it S make a sound like" bun bun " that S all... After 1-2 minute again..
The sound you're hearing could be due to a variety of reasons, such as a loose connection, a malfunctioning component, or a power issue. Here are some steps you can take to troubleshoot the issue:
Check the speaker connections: Ensure that the speaker wires are properly connected to the receiver and the speakers. Make sure that the positive and negative terminals are correctly aligned. You can also try disconnecting and reconnecting the wires to ensure a secure connection.
Check the power source: Ensure that the receiver is plugged into a working power outlet and that the power cord is securely connected to the receiver. You can also try plugging the receiver into a different power outlet to see if that resolves the issue.
Check the volume level: Ensure that the volume level on the receiver is not set too high. High volume levels can cause distortion and other issues.
Reset the receiver: Try resetting the receiver to its default settings. To do this, turn off the receiver and unplug it from the power source. Wait for a few minutes, then plug the receiver back in and turn it on.
If these suggestion don't help, you may have to seek professional repair.
2/2/2024 9:08:57 PM •
JVC Audio...
Answered
on Feb 02, 2024
1997 JVC RC-X270 does not read CDs
A bit of basic knowledge is required first;
Insert CD, the first thing the processor expects is to scheive Focus.
When Focus is acheived, the Spindle Motor will turn.
Either the Laser cannot Focus or there is an issues with the Spindle Motor.
Which is it ... if you know, then you will know which part or board has the issue.
1/29/2024 6:36:28 PM •
JVC Audio...
Answered
on Jan 29, 2024
