20 Most Recent
JVC TH-M303 System Questions & Answers
WONT PLAY COPIED DVDS ANYMORE
were you able to play copied dvd's on this unit ? if yes then check setting on the dvd menu for things like DVD REGION and DVD playback speed and types of DVD playable, this is quite likely as i ha this problem on a pioneer model previously.
do those copied dvds no longer play on the same unit ? and you have tried them again on another unit or dvd player ?
rather i suspect problems with the DVD burn itself and its compatibility with the dvd player you are palying them on now (asuming settings in DVD enu are correct as loosely outlined above in point 1)
it may be that if this is a new dvd player than the one you played them on before, the dvd's may have to be closed in a certain way using your burning software so that they are playable on standard dvd players.
please also check that region is not an issue and that the recording speed of the dvd (the rip speed) is not too high or too low for your unit, as this data is stored on the written dvd and is responsible for the quality of the palyback data.
Auto muting
Sounds like something inside went south. You can try disconncting the speakers and see if it still happens. If so, then the system is in need of repair. If not, then a speaker may be shot. Try connecting one speaker at a time to see which one may be causing the auto-mute problem.
Hope this helps, and please rate my advice, good OR bad.
My dvd player is locked
If you are unable to get the tray of the dvd player open either the player will have a hole in front for you to stick a (I use a straightened out paper clip) into and press in towards the dvd player. It will manually open the drive so you can retrieve your dvd or there will be enough of a lip on the tray door you can grab it and pull it open manually. Then I would try unplugging the player and waiting a few minutes and plugging it back in and you might get lucky and it may never happen again. Good luck . Hope it works.
When i put the
"Auto Muting" in the context of FM means the output will be muted if the signal is so weak it would result in mostly noise anyway. Interstation radio noise can be annoying and dangerous at high volumes.
I would like the owners
You can download the instruction manual in PDF format by clicking this
link.
Adobe PDF Reader is required to view this manual.
Click here to download the latest version of Adobe Reader
Thanks for using
FixYa
I am getting the locked display
Hi Blackhawk,
This sounds like you've accidentally set the "tray lock" feature.
You can set this to stop unwanted tray ejections:
I hope this solves your problem..
Warm Regards
Mike
Sub dont play when in
it could be the setting you are in sometimes there is different settings when you are i different modes just go in and change them and you will be fine and it should work just look at the manual and follow it
