20 Most Recent
Printronix Line Matrix P5010 Printer Questions & Answers
Driver download
You can use the P7000 Driver from the manufactures website.
IBM Proprinter driver 64 bit
There is no proprinter Driver for 64bit. You can use the Epson emulation or the P7000 driver with the printer in its native emulation.
15 Volt CTL fail
Hi Serap,
If a fault condition occurs in the printer, the status indicator on the control panel flashes on and off, and the message display indicates the specific fault.
For the operator-correctable faults, After correcting the displayed fault, press the CLEAR key to clear the error message and status indicator and resume printing. If the fault message reappears, contact your authorized service representative.
If a fault is not correctable by the operator, you may try two steps to clear the fault before calling your authorized service representative:
1. Set the printer power switch to O (Off), wait 15 seconds, then turn the printer on again. Run your print job again. If the message does not appear, it was a false indication and no further attention is required.
2. If the message reappears, press the CLEAR key. If the message disappears, it was a false indication and no further attention is required. If the message reappears, call your authorized service representative at 1-800-243-3338.
Message
Explanation
Action
15V CTL FAIL*
Controller voltage failure.
Contact authorized service representative.
Call 1-800-243-3338
As far as software for the flash file is concerned , I have checked with their officaial sites , but they donot have any firmware updates.
Thanks
We are using printronics
Dear friend,
Try to change the setting like Emulation mode to ESC/P ,or IBM,CPI Setting,Font settings.
Printronix p5010 with AS/400 IBM server
I can get the P5010 printing on your AS400... But, there are to many things to check without knowing a little more about your environment.
If you can't ping the PTX P5010 from the AS400 or a PC, then you have a printer configuration problem.
Take the printer offline and hit the Print Config button. and then the enter on OPs Panel. Then post top or first paragraph of the config. so I can look at...
__________________________________________________________
If you can ping the printer from the AS400...
You will need to create a remote out que on AS400... command is crtoutq then hit F4...
if you can't post the printer config here... Fax it 972-233-7306, Attn: P5010, Toby
Close platen signal
When you open and close the platen lever you will notice micro switch that should be engaged... When the lever is down to A - C. looks like this... only 2 other things it could be besides the switch...
152417-001
P5000 Platen Interlock Switch
If anybody has been in the printer where PCBA's are, check the two cable connectors holders... seated good... worst case,it would be very rare if its CMX Board(main logic)...
Power 48v check
Hi
Either the power supply is
not generating a proper 48
Volts or the controller board
is not detecting a 48 Volt
output from the power
supply board.
1. Make sure the power supply
board is correctly connected to
the controller board.
2. Power on the printer. If the
message appears, do the power
supply operational check (page
195). If the power supply fails the
check, replace it. If it passes the
check, go to the next step.
3. Power on the printer. If the
message appears, replace the
controller board. Record the
message and return it with the
defective board.
Why show erorr shutal jam
The shuttle is actually the print head.If turning machine off and then back on doesn't fix the problem then you will have to replace the shuttle.
Processor halted NOV RAM error 3
This is usually due to a bad main board. Occationally you can reload the microcode to fix it but not normally. Get the part number off the main board as there are 2 kinds and they are not easy to intercahnge.
12/16/2013 11:40:20 PM •
Printronix...
Answered
on Dec 16, 2013
Error code : E03E DSI
An ******* or unsupported
instruction was attempted
in the application
program.
1. Cycle Power. Run the print
appears, load the latest
emulation software.
2. Cycle power. Run the print
appears, record the display
message and send it to your
next higher support facility.
