20 Most Recent Printronix Line Matrix P5210 Printer Questions & Answers
Hello Fadel,
I emailed 2 different Emulation files...
Let me know if you receive an error. If you get Flushing Ques after you started the download, then you don't have enough Dram memory, Flash memory or Security Pal chip needs a specific Emulation file.
Printronix Line... | Answered on Aug 22, 2016
Yes the aftermarket ribbons are re-inked ribbons and are bad for the frets. If your tech cleaned the frets with an abrasive tool or chemical other than alcohol then he removed the protective film and the frets are bad.
Printronix Line... | Answered on Apr 04, 2015
There is not a windows 7 driver for the P5000, but the P7000 driver has been fully tested by Printronix to work with the P5000. Alternatively you can use the printer in Epson emulation mode and use the Epson 1080 driver included in Windows7.
Printronix Line... | Answered on Feb 26, 2015
in same way as well as generic printer installed on pc
Printronix Line... | Answered on Jan 08, 2015
Logic card having problem
Depends on the code needed, I configure CMX boards in-house and ship them out all the time. Just need a config from your printer in order to match it up. cardenas_rory@hotmail.com
Printronix Line... | Answered on May 15, 2014
this is your data cable problem change datacable
and change setting to your computer cmos setup
go cmos setup find parralal port mode option select EPP+ECP
First you change your datacable if problem can't solve so change
cmos setup option
Printronix Line... | Answered on Oct 09, 2012
1. copy file name lpt1 (parallel) 2. copy file name com1 (serial)
Printronix Line... | Answered on May 02, 2011
Press the up and down arrows at the same time to unlock.
Printronix Line... | Answered on Mar 05, 2011
www.printcountry.com/drivers/PRINTRONIX_P5220_GOLD_SERIES_2000_DRIVER_DOWNLOAD.htm
driverscollection.com/?H=P5220&By=Printronix
http://driverscollection.com/?H=P5220&By=Printronix
http://www.printcountry.com/drivers/PRINTRONIX_P5220_GOLD_SERIES_2000_DRIVER_DOWNLOAD.htm
tyr anyone of these
Printronix Line... | Answered on Oct 22, 2010
If I'm not mistaken, the manual can be found at this link
http://www.printronix.com/products/productmanuals.aspx?id=4108
Please rate if you find this helpful, thanks
Printronix Line... | Answered on Jun 16, 2010
From this Link :
http://www.printcountry.com/drivers/PRINTRONIX_P5209_DRIVER_DOWNLOAD.htm
OFTEN the cause of alignment problem is that the paper tractors are too loose and paper moves more than it should. It takes careful adjustment of the tractors to hold paper just right when the hammers hit the characters. Too tight and the tractors tear out the edges, too loose and characters rattle around in alignment.
OTHER problems can be caused by TOO LOW humidity which causes electrostatic attraction and drag. SOMETIMES they use an ionizer bar and the high voltage power supply goes bad. Another thing is drag from the stack of paper source.
Printronix Line... | Answered on Oct 26, 2009
Printronix Line Matrix P5210 Printer Logo
Popular Tags
36 questions posted
Top Printronix Office Equipment & Supplies Experts
Chinmay Joshi
Chinmay Joshi
Thomas F. Schneider
CheckitRight
CheckitRight
Are you a Printronix Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Matrix Printronix
  • Matrix Printronix
Most Popular Question
wan download
  • Office Equipment & Supplies
