20 Most Recent
GE GFSS6KKYSS Questions & Answers
Water line Up back of unit to what I assume is the
Most likely what caused it to blow out is the feed tube going through back refrigerator wall is frozen not allowing water to flow. You can probably just reconnect 1/4 inch tubing once feed tube is cleared.
No water or ice
check to make sure water to valve in back lower section and be sure no water line is crimped if water at valve check voltage when pushing the water dispenser if there is voltage , bad water valve if not swith at dispenser
11/23/2013 11:28:47 AM •
GE GFSS6KKYSS
Answered
on Nov 23, 2013
I do not get ice or water
Without water you will not get ice anyway, my suggestion is to check the water line into the unit & make sure it hasn't kinked anywhere.
