20 Most Recent GE 24950 Remote Control Questions & Answers
2answers
Need to find a code for my tv
What make and model TV do you have?
10/13/2014 1:30:26 AM • GE 24950 Remote... • Answered on Oct 13, 2014
0answers
0answers
I have a GE universal remote& Emerson tv
You did not mention model numbers of TV and Remote Control. Anyway I am sharing following three useful links for you help. GE Universal Remote Codes: How to Program Any Device - PC Guide How to Program Your Universal Remote (byjasco.com) GE Universal Remote Codes List and Program Guide (Updated) (ytechb.com)
1/5/2024 12:24:53 PM • GE Televison &... • Answered on Jan 05, 2024
Trying to find model number on my GE universal remote so that I can get codes for my converter box
Locating the model number on a GE universal remote can vary depending on the specific model. Here are some general tips to help you find the model number:
  1. Check the Battery Compartment:
    • Open the battery compartment on the back of the remote.
    • Look for a sticker or label inside the compartment that may contain the model number.
  2. On the Remote's Front or Back:
    • Check the front and back of the remote for any labels or markings that might indicate the model number.
  3. User Manual or Packaging:
    • If you have the user manual or the original packaging, check there. The model number is often mentioned on these documents.
  4. Behind the Battery Cover:
    • Remove the battery cover and inspect the area behind it for any labels or markings that include the model number.
  5. On the Remote's Body:
    • Inspect the body of the remote itself. Some models may have the model number printed on the front or sides.
Once you locate the model number, you can then proceed to find the correct codes for your converter box. The codes are usually included in the remote's manual or can be found on the manufacturer's website. If you are unable to find the model number or the manual, you may need to contact GE customer support for assistance. If you provide more details about your GE universal remote, I might be able to offer more specific guidance.
11/26/2023 6:19:57 PM • GE Televison &... • Answered on Nov 26, 2023
Need universal remote codes for sansui hdlcdvd265b
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote 4 Digit Universal Remote Codes for Sansui TV ; 0394, 5871, 1052 1556, 1208, 0135 ; 0888, 0310, 6071 ; 6061, 0806, 5441 ; 2832, 0264, 1230.
Replacement Remote Control for SANSUI HDLCDVD265 ...
Amazon.com https://www.amazon.com > Replacement-HDLCDVD2... This is a custom built replacement remote made by Redi Remote for the SANSUI remote control number 076R0LJ020. *This is NOT an original remote control. Rating: 4.4 · ‎12 reviews · ‎US$34.95
Replacement Remote for SANSUI HDLCDVD265, ...
Amazon.com https://www.amazon.com > Replacement-HDLCDVD2... Replacement remote control for Sansui HDLCDVD265, HDLCDVD325B, 076R0LJ020 with all functions of original one. It replace each button of original remote ... US$16.00
11/24/2023 5:43:05 PM • GE Televison &... • Answered on Nov 24, 2023
Sansui hdlcdvd265b using GE universal remote channel buttons and volume buttons control volume and CC won't turn on
Closed Captioning is run from your cable box or wherever the signal comes from. You use the cable box remote, not the television remote as it isn't a 'television feature'.
11/24/2023 5:40:00 PM • GE Televison &... • Answered on Nov 24, 2023
2answers
What is GE remote code for spongebob TV ? Remote model 24922
There is no set-up codes to this brand TV with GE remote control. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box. http://electronicshelponline.blogspot.com/ http://remotesearch.blogspot.com/ http://electro-medical.blogspot.com/ http://electrohelponline.blogspot.com/
5/21/2023 4:48:31 PM • GE Televison &... • Answered on May 21, 2023
Need codes FOR GE UNIVERSAL RC 24914-D TO CONNECT MY roku express
Yes, you can use a GE Universal Remote RC24914-D to set up your Roku Express box. To do this, you'll need to find the correct code for your Roku Express device and program it into the remote. Here's how:
  1. Turn on your Roku Express device.
  2. Locate the "Code Search" button on your GE Universal Remote. This button is usually labeled "Code Search" or "Setup."
  3. Press and hold the "Code Search" button until the indicator light turns on.
  4. Enter the code 9-9-1. The indicator light will blink twice.
  5. Point the remote at your Roku Express device and press the "Power" button. If the device turns off, you have found the correct code. If it does not turn off, repeat steps 3 to 5 with a different code until you find the correct one.
  6. Once you have found the correct code, press the "Code Search" button again to save the code.
The codes for the GE Universal Remote RC24914-D can vary depending on the version, so it's possible that the code 9-9-1 may not work for your device. If that's the case, you can try other codes listed in the remote manual or on the GE website. I hope this helps you set up your Roku Express device using your GE Universal Remote.
1/31/2023 6:27:36 AM • GE Televison &... • Answered on Jan 31, 2023
Need codes for GE universal remote 24944 V3
Try here........ https://www.eliztech.com/remotes/ge-4digit-v3-tv-codes.php
1/18/2023 9:02:12 PM • GE Televison &... • Answered on Jan 18, 2023
Sansui model HDL19WB television is using an antenna from GE and that is model 14068 indoor 10 antenna. It keeps saying that my digital capacity is low or digital signal is low.
Yes, the antennae needs upgrading. It is not supplying enough signal for the television's capability and the HD programming that is now available. Or the reception where the antennae is is obstructed. https://www.manua.ls/sansui/hdlcd19wb/manual?p=24 https://www.google.com/search?q=14068+indoor+10+antenna ..
1/13/2023 3:19:52 AM • GE Televison &... • Answered on Jan 13, 2023
2answers
Ge universal remote model um3-lr06
Hi, please reach out to general electric via twitter and ask them to post the product manual for you sos that you can download it and get the codes that you're looking for. Their id on twitter is @generalelectric. Thank you.
12/10/2022 5:21:52 PM • GE Televison &... • Answered on Dec 10, 2022
How do I scan a Sansui tv please?
You don't scan the television. You enter the codes for Sansui one at a time into the remote until it works. In actual fact though, no one these days uses Universal remotes! https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote ..
12/3/2022 6:48:22 AM • GE Televison &... • Answered on Dec 03, 2022
I have a GE 13TVR70 with a blue screen
1. How to fix a GE 13TVR70 with a blue screen: If your GE 13TVR70 has a blue screen, there are a few possible causes and solutions. First, check to see if the blue screen is caused by a loose or disconnected cable. If so, simply reconnect the cable and power on the TV. If the blue screen persists, the TV may have a faulty component that needs to be replaced. Consult a TV repair specialist for assistance. 2. What could be causing my GE 13TVR70 to have a blue screen? There are several possible causes for a GE 13TVR70 to have a blue screen. First, check to see if the blue screen is caused by a loose or disconnected cable. If so, simply reconnect the cable and power on the TV. If the blue screen persists, the TV may have a faulty component that needs to be replaced. Consult a TV repair specialist for assistance. 3. What are some common problems with GE 13TVR70s? Some common problems with GE 13TVR70s include blue screens, picture quality issues, and sound problems. If you are experiencing any of these issues, consult a TV repair specialist for assistance. 4. How can I prevent my GE 13TVR70 from having a blue screen? There are a few things you can do to prevent your GE 13TVR70 from having a blue screen. First, make sure all cables are securely connected. Second, avoid using the TV in extreme temperatures. Third, do not use the TV in humid or dusty conditions. If you follow these guidelines, your TV should function properly. I hope this helps!
11/22/2022 4:47:12 PM • GE Televison &... • Answered on Nov 22, 2022
I have Emerson DVD TV model number ld260 em2 I have a GE universal remote model RC 249 14-E need codes
for this remoteThere are 4 codes listed for your TV. Try them in order: 627, 504, 667, 651.
11/5/2022 1:09:07 PM • GE Televison &... • Answered on Nov 05, 2022
GE 24950 Remote Control Logo
Popular Tags
8 questions posted
Top GE Televison & Video Experts
ExpressFiX
ExpressFiX
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • GE Televison & Video
Most Popular Question
need find code tv
  • Televison & Video
