20 Most Recent
Jensen Vm9214 Car Video Player Questions & Answers
Problems playing cds n dvds
hi there
the problem you are probably inquiring is a dirty cd dvd lens this is a simple fix go to local electronics or walmart store and ask for a cd lens cleaning cd this will usually fix the problem and is fairly inexpensive that should take care of your issue
thank you any other questions feel free to post
Why is my My Jensen VM9214 stuck on camera mode
Check your wires, theres a wire for the reverse if your going to use a back up camera, if not do not connect it, you may have had it connected through a speaker wire, if so then thats your issue and once you wire it up right it wont do that any more, had the same issue and thats what fixed it hope this helps
I would like to replace the flatwire ribbon that
go to jensen online they should have the part you are looking for take the old one out and go buy the pics on the site count the wires and plug pins and try to match the colors cause sometimes they will change good luck
Hav this player nd it
The touch screen in most cases will need to be replaced because it developes a short in the membrane making it inoperative. Since you have a remote and you have full access I recommend using it the way it is. However if you wish to track down the part, ebay is a good source for parts and may have what you are looking for.
How do I find out the code to allow me to bypass
On the main remote press stop twice, then 1, 2, 6, 4. This will get you to the hidden menu which will allow you to bypass the parking brake having to be on. It will also give you an option to play burnt movies:)
I have a jensen vm9214
Hi timkilian,
If your
iPod won't play, it might caused by some
setting on your
Jensen vm9214. Also please ensure that your
iPod has the latest
Apple firmware to avoid any connectivity issue. Please visit this
link for additional information on how to operate the
iPod on the
Jensen VM9214.
Hope it helps.
Thank you for using FixYa.
