20 Most Recent
Jensen VM9020TS Car DVD Player Questions & Answers
Where is the reset button on jdvd300mk11
If there is a reset switch, it will be a pencil tip sized indentation on the face, It will not be marked. If there is no reset switch, you can reset the radio by disconnecting the battery for a few seconds.
My screen does not play
As it's illegal to view your screen while the vehicle is in motion, DVD players are required to be connected to your park brake switch, so viewing can only occur when the park brake is applied.
From what you have described, I suspect the wiring (or switch) connecting to your park brake switch, may have a short, or the switch itself may be faulty.
Hope this helps....
Amp to jensen uv8 hook up
to fix your problem cut the wire in half connect it to a ground and hot and there ya go it fixed my problem
I got a Jensen VM9020TS
Please try to put in an ordinary audio CD track and see if this is detected. If yes the optical is working, if not there is no laser scanning and the possibility of the head being faulty is high.
Now certain cleaner disks are not read and so will not be tracked.Try to open and do a cleaning manually of the laser head eye with a cotton bud very softly and without any pressing of the lens eye.
make sure that the Cd is loading into the drive and sets into the head if not the loading mechanism has some errors and must be reset for proper loading into the slot. possible obstruction or dirt accumulation must be checked.
I have no sound in
Hello, my name is Israel I will try to help you out. Are you using amplifiers connected to the unit and also are you using the rear speaker wires from the unit on any of the speakers on the vehicle.
No sound
hi! press the audio setting and set on the audio set on
Why is the uv9 telling me usb not supported
the audio format may not be supported...if the files are supported than it might be the file protecting switch (dont know exactly what its called.) if not then i apologize thats passed me...
