20 Most Recent
Brother MFC 580 All-In-One InkJet Printer Questions & Answers
How to change Brother MFC 5890CN Language
Please follow the instructions below to change the language to English.
1. Turn off the machine
2. Hold in the MENU button.
3. Turn on the machine while holding the menu button
4. Maintenance should come up onscreen and the lights should flash.
5. Key in the numbers 74 and press Mono Start button.
6. Key in 0004 and press Mono Start button.
7. "MAINTENANCE" appears again on the display.
8. Key in 99 at the maintenance prompt to exit to the date and time
It should be now in English.
I followed your solution you provided to change
Hi Nicolas, please becarefull when using service mode it is really not a place anyone should be playing in as you have found out it can render machines useless.. So enter service mode by pressing menu * 2 8 6 4 very fast... machine should display maintence.. then once you see maintence press 7 and then 4, the present code is then displayed (your wrong code is probally 0001 usa, or 1004 denmark/netherland), .. Now enter in correct code for a mfc9320CW in Netherlands its 0209, or 0201 for USA, or 0213 denmark, I gave you a few because I dont know what country you are in..then press ok, the machine will save the setting and displays parameter init, the machine should then beep and return to maintence mode, to exit mainence key in 99. Let me know how you go or if I guess wrong your countryCheers Soulvisitor
Drivers for printer Brother MFC-580
You can download the installation driver and software from manufacturer's site by clicking this
link
On the page which opens:
- Select the operating system of your computer (Windows Xp/ Vista..) from the drop-down list
- Select the Language (English) and click the Search button
- Download and install the Full Driver & Software Package from the next page which opens.
Hope this solves your problem. Thanks for using FixYa.
I am getting error code 41 on my MFC 580. Can I
Hi there
Error 41 means there is a major problem with the printhead, usually
requires a print head replacement.
My advice is to take it to a
Brother service centre while if it is under warranty.
If it's out of warranty they are usually a throw away job, the heads cost as much as the printer.
Sorry I know what it feels like, just have a go and see what you can do, clean the heads and so on.
All the Best and good luck: Pineworks
Brother MFC scanner bar is stuck
check the continuty in scanner cable to cis unit and check the continuity 2ends off scanner cable.
1.cable problem
2cis problem
Cannot reset toner counter for Brother MFC-9140CDN printer
You can reset the toner cartridges via the printer's menu.
- if an error message appears on the LCD display, press the Cancel (X) button to show the main menu.
- Press the Fax button to make the numeric keypad visible. Then, locate and only locate the Asterisk (Star) button on the numeric keypad. It is important to remember its location as it will not be lit up later when needed.
- Press the Home button to return to the main menu.
- Open the front cover of the printer (to access cartridges).
- With the front cover open, press and hold the unlit Asterisk (Star) button for 5 seconds.
- The reset menu will now appear on the LCD display.
- Scroll through the menu to select a color and yield to reset.
- The LCD will read "Accepted" once the reset is complete.
http://www.zinetic.co.uk/brother_mfc_9140cdn_toner_refill_kit-news.aspx
Scan unable af
The scanner unit is faulty or the flat harness was not fitted properly to the main board.
