20 Most Recent Brother MFC-620CN All-In-One InkJet Printer Questions & Answers
Brother MFC 620CN - "Machine Error"
Put in trash. Buy new machine.
5/3/2017 2:46:05 AM • Brother... • Answered on May 03, 2017
2answers
Unknown error message UNABLE TO INIT. printer just stopped working
press menu then start bk-copy then fourtimes arrow up. machine switches to maintenance mode. press start bk copy. what two digit error code does the display show off? Post here again
1/5/2015 4:04:27 AM • Brother... • Answered on Jan 05, 2015
2answers
Error message
press menu then start mono then 4 times arrow up. machine will be in maintenance mode. What error code does the display show up? plz post here again. To leave maintenance mode press 9 then 9.
12/31/2014 7:12:30 PM • Brother... • Answered on Dec 31, 2014
Can not detect ink
Hi, You must undergone deep cleaning first in the maintenance tab.
6/30/2014 3:57:12 PM • Brother... • Answered on Jun 30, 2014
Brother MFC-620CN printer unable to clean error
Often means something is blocking the printhead from traveling all the way left & right. Look carefully in there, especially under the ends, for a scrap. It may be black with ink and hard to spot, but if you see it, a minute with some tweezers may fix everything.
Sometimes the timing strip gets knocked out of its sensor, so the machine can't detect whether it's moving when it turns on the motors, so it locks up with that error. Getting to that is a bit trickier. Open the top and pry out a couple of skinny plastic covers that hide cables. One of those covers acts to lock in the lever that holds the top section up; once you've removed the cover, you can unsnap the lever from the bottom end, allowing you to stand the top (scanner) section straight up. Take a good look at the cables & how they're laid. The flat white one is especially delicate, and must not be reinserted crooked. Unplug those cables and pull them out of the way so you can remove the top cover they're laid in. There's also a ground wire to unscrew.
The top is held on with what - six or seven screws? Keep track of which goes where. I think the front edge is caught by a plastic hook, also. Free it by prying with a small screwdriver, and lift off the top cover.
The whole printer mechanism is now exposed. You can see the 1/4-inch (6mm) wide strip of film that's stretched tight across the entire width of the printer area. The gray in that strip is hundreds of fine vertical lines. A sensor in the printer head carrier shines through those lines and counts them to keep track of where it is at all times. If you find the film strip laying flat across the top of the printhead, just lift it carefully and lower it into its slot in the sensor. It should be vertical and straight. Don't get ink or fingerprints on that strip; it can be cleaned - very gently - with a damp cloth.
Put the cover back on, install those cables, the lever that holds the scanner up, and the little covers, and try it out.
If it's not a paper scrap or that timing strip, it's probably too expensive to mess with, but check with the closest service center listed on Brother's website. If none appear to be close enough, don't be shy about calling one of the closest ones and asking if they have another branch that's not listed on Brother.
6/30/2014 10:45:11 AM • Brother... • Answered on Jun 30, 2014
Brother MFC 620CN - error message
Unable to clean usually means the waste ink tank is full, you'll need it replaced by a shop so they can reset the counter as well.
6/30/2014 10:43:39 AM • Brother... • Answered on Jun 30, 2014
Unable to cl;ean
Hi Ada, Go To Below official Brother Printer Video For Your problem, Still having Problem Then follow Us For Brother Printer Support
2/24/2014 8:43:59 PM • Brother... • Answered on Feb 24, 2014
0answers
Maintenance
Be the first to answer 1/20/2014 4:06:04 PM • Brother... • Posted on Jan 20, 2014Be the first to answer
I just want to scan.
From past experience and current research, you can not scan with an error on the LCD screen. Therefore you would have to replace the ink before the scanner will work.Sorry to be the bearer of bad news.
12/9/2013 1:00:26 AM • Brother... • Answered on Dec 09, 2013
2answers
Brother MFC-420cn
Change the black one. It could be that the cart is mal manufactured (valve wont open). Use another one and see if there is bk again. When no success after the 2. cleaning cycle try this: http://www.fixya.com/support/t202678-printer_head_cleaning If there is more trouble post here.
10/25/2012 1:31:03 AM • Brother... • Answered on Oct 25, 2012
Paper not feeding
Is this a top feed - that is paper loaded on top at the back bottom feed from a tray underneath? Top feed take one sheet of paper and gently push it down whilst the printer is trying to grab it. Tray feed - take tray out make sure no paper fragments are in the tracks and find a nail board and gently abrade the pick up rollers.
10/14/2012 7:06:55 PM • Brother... • Answered on Oct 14, 2012
2answers
Shut down after job complete
I had same problem on a MFC-3820CN Brother advised as follows:
"If the cover is opened during the power-down routine, when putting the machine into Power Save mode using the Power Save key, the LCD will display the message you mention in your email. The problem can be fixed by disconnecting the power cord and then holding down the on/off button while re-connecting the power cord again."
While waiting for brother to get back to me I accidentally put machine into maintainence mode and then when I re-powered up the problem was gone so I have not tried above myself, but can confirm problem is fixable.
10/25/2011 7:17:11 AM • Brother... • Answered on Oct 25, 2011
Hi could you tell me how to print the report for
Customizing the Transmission Verification Report You can use the Transmission Report as proof that you sent a fax. This report lists the time and date of transmission and whether the transmission was successful (OK). If you select On or On+Image, the report will print for every fax you send. If you send a lot of faxes to the same place, you may need more than the job numbers to know which faxes you must send again. Selecting On+Image or Off+Image will print a section of the fax's first page on the report to help you remember. NOTE:When the Verification Report is turned Off or Off+Image, the Report will only print if there is a transmission error, with NG in the RESULT column. 1 Press Menu/Set, 2, 4, 1. 2 Press ? or ? to select Off+Image, On, On+Image or Off. Press Menu/Set. 3 Press Stop/Exit.
7/21/2011 5:16:26 AM • Brother... • Answered on Jul 21, 2011
2answers
My sister has a mfc 210c and it says cant clean
Hi you can try
This works with most Brother printers
Procedure how to reset the error 46 error (unable to clean). This can be done on every Brother inkjet machine with a numeric keypad.
- Machine off
- Switch on the machine while holding down the “menu” button until all the leds are flashing on/off. Now you are in “maintenance” mode.
- press 80
- press the “mono start” button several times until you see “purge: xxxx”
- press “2783” in order to reset the purge counter. You will see: “purge:0000”
- press “99” to exit the maintenance mode
Now you are able to print again, but actually your ink absorber box is now full with ink. Ink flooding can happen if you don’t replace this ink box
Also can try.
Reset code.
Press menu then*2864 within 2 seconds (maint should be on the display and all the lights should be flashing, if not try again) press 80
then keep pressing black/mono start button until screen displays ‘purge count’
press 2783 to reset purge count
press stop/exit key
press 99
machine should return to normal
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
7/15/2011 2:10:50 PM • Brother... • Answered on Jul 15, 2011
2answers
How to change instructions from german to english
Keep navigating through the menus on the printer's LCD screen.
Open your web-browser to:
http://www.google.ca/language_tools?hl=en
which lets you type in text, in German, and Google will translate it to English (or Klingon), so that you can read each sub-menu, and make the correct "click" to reset the printer's language.
3/2/2011 7:41:59 PM • Brother... • Answered on Mar 02, 2011
2answers
Please driver cd
You candownload the Brother printer drivers from their support WEB site. Please clickon this link and select your model printer to download :-http://www.brother.com.au/ProductsSolutions.aspx
2/26/2011 8:43:48 AM • Brother... • Answered on Feb 26, 2011
0answers
NO BLACK INK COMING THROUGH ALTHOUGH I HAVE
It needs a new print head. Brothers are notorious for this issue. Especially if you are using generic ink and not Brother branded.
11/3/2010 1:40:14 PM • Brother... • Answered on Nov 03, 2010
Mfc-620cn prints all colors but
It seems simple enough, but this is one of the most effective ways of fixing printer cartridge error. Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached.
To reattach the cartridge check the following steps :
turn on the lid of the printer and then remove the cartridge from the printer head.
Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report.
Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
10/26/2010 5:37:57 AM • Brother... • Answered on Oct 26, 2010
Brother MFC-620CN All-In-One InkJet Printer Logo
68 questions posted
Norman Weimar
Norman Weimar
k24674
View Most Popular
MFC Brother
  • MFC Brother
Most Popular Question
just want scan
  • Office Equipment & Supplies
