20 Most Recent Samsung PN60F5500 60-Inch 1080p 600Hz 3D Smart Plasma HDTV Questions & Answers
Plasma tv repair
Samsung 50 inch plasma wont turn on - YouTube
? 0:59 https://www.youtube.com/watch?v=Uo-SazF_G9Y Jan 9, 2014 - Uploaded by 8Jallin Samsung 50 inch plasma wont turn on ... samsung plasma tvnot working, wouldn't turn on, FIXED, repair, diy - Duration: 14:56. by Matthew ...
Plasma TV Repair Tutorial - Common Symptoms ... - YouTube
? 7:13 https://www.youtube.com/watch?v=gnkyAGyI7GA Oct 9, 2013 - Uploaded by ShopJimmy.com Plasma TV Repair Tutorial - Common Symptoms & Solutions - How to Fix .... Samsung 50" Lcd tv model#Lf501EM6f Im not sure if its plasma or ...
WHAT Plasma TV BOARD CAUSES NO PICTURE REVIEW ...
? 4:10 https://www.youtube.com/watch?v=DC_75FfrR9w Nov 8, 2012 - Uploaded by Tampatec WHAT COMMON PART / TV Board IS BAD ON SAMSUNG Plasma ... a gamble. it the cost of repair is over 300 just buy a new 50 inch tv for 600. Samsung 50" Tv Power Supply Boar...$34.00eBaySAMSUNG UN60EH6002FXZA...$23.00TV Parts Guy42% price dropSamsung 50" Pn50c550 Pn50c45...$18.99eBay
9/23/2019 1:23:57 AM • Samsung... • Answered on Sep 23, 2019
Samsung television black shadow fix?
bro you should take it to the repairer,No other options you have. it can't be fixed by doing anything accept changing it's screen or repairing it, if it's possible
4/23/2024 1:56:46 AM • Samsung... • Answered 3 days ago
Why is my Samsung plasma tv screen becoming dark suddenly meanwhile it's on and still functioning
Hello. You can check HDMI cable in this case. If you're using an HDMI port that's not working well or has been damaged, it could result in a darker-than-usual screen. If you switch the cable or change devices and the TV is at a regular brightness, this is the case.
4/17/2024 5:31:49 PM • Samsung... • Answered on Apr 17, 2024
2answers
Samsung 55 TV White vertical patches?
It sounds like you might be dealing with backlight bleeding or an issue with the LED backlighting in your TV. This can sometimes occur over time due to normal wear and tear or manufacturing defects. If it started as a faint single brighter section and has now expanded to four, it's likely a hardware issue. While it may not be an easy fix, contacting the manufacturer's customer support or a professional technician would be a good next step to diagnose and possibly repair the problem. If you'd like, you can share the pictures for a more accurate assessment.
4/14/2024 7:29:30 PM • Samsung... • Answered on Apr 14, 2024
Samsung plasma tv repair PN51F5300BFXZA
All I can advise is to take it to an authorised Samsung repair shop. A list is available on the Samsung web site.
4/7/2024 8:20:50 AM • Samsung... • Answered on Apr 07, 2024
2answers
Samsung VHS VR8360C - if i use a three colour av cable on the VHS end and go to an HDMI connector at LG tv end will this work or do I need a converter?
The old yellow, red, white RCA cables are analogue signals, while HDMI cables only carry data. They are in no way compatible. You can buy active conversion boxes that will convert analog to digital, but simple cables cannot work
3/23/2024 10:44:12 PM • Samsung... • Answered on Mar 23, 2024
Remote code for Samsung remote to LG tv
It can't be done. The Samsung remote will be single frequency for that Samsung device only and the LG remote for that television (or series) only. Companies don't make cross-control between makers easy. The only exception is cable and satellite boxes to allow their remote to also control the television. If you have lost a remote or it doesn't work, this is the answer https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote ..
3/19/2024 3:17:28 PM • Samsung... • Answered on Mar 19, 2024
Samsung un55nu6950fxza TV
These LEDs are very susceptible to static electricity damage. What happens when they get zapped is a tiny threading fault starts in the LED crystal. The aluminum contact metal starts migrating into the crack, makes it wider and longer, and eventually goes all the way through the LED and shorts it out. When that happens, the metal overheats and burns out the LED so the entire string goes dead. What this means for you is that the original LED may have been may have been zapped at the factory. The replacement strip likewise, or when it was removed from another TV (if it is a used part), or when you put it in. It should have been in anti-static packaging. You have to be very careful not to touch any of the circuitry on the LED strip, and make sure you ground your hand to the TV metal both before picking up the LED strip and right before connecting the strip to the TV. Better yet, use an anti-static wristband connected to the TV frame. It is possible that the LED driver for that string is pushing too much current, but that's not likely. You would probably notice that part of the screen is unnaturally bright.
2/5/2024 6:37:37 PM • Samsung... • Answered on Feb 05, 2024
2answers
A resistor got burned on my samsung HT-E330K. I do not know its value because it got burned. Does anyone knows what it is?
Can you tell this power supply board zener doide value?
2/5/2024 2:11:29 PM • Samsung... • Answered on Feb 05, 2024
2answers
Brand new Samsung 77 OLED tv. Got knocked off the stand and fell on and bent the lower corner
It sounds like your TV has a display issue, likely caused by physical damage to the screen due to the bend. Repairing a damaged screen can be quite expensive, often nearing or exceeding the cost of a new TV, especially for larger screens like the one you described. Here are a few options you might consider:
  1. Sell it as is: You can try selling the TV in its current condition, clearly describing the issue with the display. Some buyers may be interested in purchasing it for parts or attempting a repair themselves.
  2. Attempt a DIY repair: Depending on your technical skills and willingness to take on the challenge, you could try to repair the TV yourself. However, this can be risky and may void any remaining warranty. There are online tutorials and replacement parts available, but again, this route requires some technical expertise.
  3. Professional repair: You could contact a professional TV repair service to get an estimate for repairing the screen. Be sure to weigh the cost of repair against the potential selling price of the TV after it's fixed to determine if it's worth the investment.
  4. Sell for parts: If repairing the screen is not feasible, you could dismantle the TV and sell its components individually. Some parts, like the internal circuitry or casing, may still hold value to electronics enthusiasts or repair professionals.
  5. Trade-in or recycle: Some retailers offer trade-in programs where you can exchange your old electronics for store credit or discounts on new purchases. If the TV is beyond repair, you can also look into recycling options to properly dispose of it.
Ultimately, the best option for you will depend on the extent of the damage, your budget, and your willingness to invest time and effort into repairing or selling the TV.
2/4/2024 5:20:05 PM • Samsung... • Answered on Feb 04, 2024
Samsung TV went blank and won't turn on
2/2/2024 8:15:51 AM • Samsung... • Answered on Feb 02, 2024
Samsung plasma model PN60F5500, has sound, no picture
See troubleshooting section of user manual for help Troubleshooting - Samsung PN51F5500 User Manual [Page 21] ' ManualsLib
1/30/2024 7:50:08 PM • Samsung... • Answered on Jan 30, 2024
Samsung U55HU9000 curved LED with intermittently displaying green vertical lines. Vanishes after an hour. Power supply issue?
Possibly, or dry joints, or failing Caps. Get your meters and oscilloscope out. ..
1/28/2024 11:17:04 PM • Samsung... • Answered on Jan 28, 2024
3answers
How to reset samsung UE55D7000
Hold down the EXIT button for 30 seconds
1/25/2024 9:25:07 PM • Samsung... • Answered on Jan 25, 2024
Samsung un50nu6950 wont turn on? It will after 20 or so tries. Standby light is on. Same problem with hard switch attempts?
It's a Samsung and has power supply issues. Repair/replace the power supply and that should get you going, if nothing else is damaged.
1/21/2024 8:13:56 PM • Samsung... • Answered on Jan 21, 2024
2answers
My Samsung TV keeps turning on and off. Anyone can help?
see if program set in power set up if no program possible power transformer or board going out
1/14/2024 11:24:48 AM • Samsung... • Answered on Jan 14, 2024
Component units not displaying color
I think you need to check the color settings on your new LG TV and ensure all cables are securely connected. If the issue persists, you don't have further options except to contact LG support for assistance.
1/5/2024 8:10:23 PM • Samsung... • Answered on Jan 05, 2024
I have Samsung 42 inches plasma TV model-Ps42c430a1 and Sr - 189938YB400505D it's red light blinking 6 times and tv create clicking sound no picture & sound who to fix it ?
I suggest an authorised Samsung repair agent, (a list can be found on the Samsung web site), otherwise you will get panel changers and not engineers that repair to component level. One common culprit of this issue power supply issue, caused by a faulty power supply unit or the TV not receiving enough power, caused by faulty electrolytic capacitors on the Power Supply board.
12/31/2023 4:28:41 PM • Samsung... • Answered on Dec 31, 2023
Would like to fix plasma Samsung TV PN59D8000FFXZA
See troubleshooting section of this manual. It will help. [ENG_US]GPATSCA-1025.pdf (samsung.com) For further help you can use following link PN59D8000FF ' Samsung Support CA
12/31/2023 11:23:55 AM • Samsung... • Answered on Dec 31, 2023
Samsung PN60F5500 60-Inch 1080p 600Hz 3D Smart Plasma HDTV Logo
2 questions posted
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
View Most Popular
  • Samsung Televison & Video
Most Popular Question
plasma tv repair
  • Televison & Video
