20 Most Recent
GE PT970SRSS Profile 30 Stainless Steel Electric Combination Wall Oven - Convection Questions & Answers
Oven Light Will Not Shut Off - GE Range Oven Model: PS968SP1SS
If you have already replaced the Hi-Amp Door Switch on your GE Range Oven (Model: PS968SP1SS), but the oven light still will not turn off, there are a few additional steps you can take to troubleshoot the issue:
- Check the light switch: Ensure that the light switch is functioning properly. It is usually located near the oven door frame or control panel. Press the switch manually to see if the light turns on and off. If it is not working, you may need to replace the light switch.
- Inspect the light socket: Examine the light socket for any signs of damage or corrosion. If the socket appears to be damaged, you may need to replace it.
- Verify the wiring connections: Check the wiring connections between the light socket, the Hi-Amp Door Switch, and the main control board. Ensure that all connections are secure and properly connected. Loose or faulty wiring can cause the light to stay on.
- Test the main control board: As you suspect, a faulty main control board could also be the cause of the issue. You can try resetting the control board by turning off the power to the oven at the circuit breaker for a few minutes and then turning it back on. If the light still does not turn off, it may indicate a problem with the control board that requires replacement.
If you have performed these troubleshooting steps and the light still won't turn off, it would be advisable to contact GE customer support or a qualified technician for further assistance. They will be able to diagnose the problem more accurately and recommend the appropriate solution.
6/18/2023 4:55:39 PM •
GE Ovens
Answered
on Jun 18, 2023
I have a GE rapid clean II J55BF-1 wall mount oven needs to replace the baking element. Did someone happen to know the part number of the replacement baking element ?
To find the correct replacement baking element for your GE Rapid Clean II J55BF-1 wall mount oven, you can try the following steps:
- Locate the model and serial number of your oven. This information is usually found on a label on the inside of the oven door or on the back of the oven.
- Visit the GE Appliances website or use an online appliance parts retailer to search for the part using your oven model number.
- Look for the baking element part number in the oven's user manual or service manual. These manuals may be available online or from the manufacturer.
- If you are still having trouble finding the correct part number, consider contacting the manufacturer's customer service department for assistance.
Once you have the correct part number, you can order the replacement baking element and follow the manufacturer's instructions for installation.
2/26/2023 11:58:18 AM •
GE Ovens
Answered
on Feb 26, 2023
GE oven flashed f7 d6 error. Replaced key pad, same error again. Replaced ERC board and still f7 d6. What now?
It's possible that a faulty ERC (Electronic Range Control) could damage a new keypad, but it's not very common. The F7 D6 error code indicates a problem with the communication between the keypad and the ERC. Here are a few other things you could try:
- Check the ribbon cable connection between the keypad and the ERC. Make sure it is securely connected and not damaged in any way.
- Try resetting the oven by turning off the power to it for a few minutes, then turning it back on. This may help clear any temporary glitches that are causing the error.
- If the above steps don't work, it's possible that there is a wiring problem or a faulty component in the oven that is causing the error. In this case, it may be best to call a professional appliance repair technician to diagnose and fix the problem.
2/26/2023 10:31:31 AM •
GE Ovens
Answered
on Feb 26, 2023
GE TRIVECTION JT930S OVEN WONT COME Othe thermal fuse N
I'm sorry, I'm having a bit of difficulty understanding your question. Could you please provide more information or clarify what you are asking for? It seems like you may be asking about the thermal fuse on a GE Trivection JT930S oven, but I am not sure what you are asking for after "where is". Thank you.
2/26/2023 6:04:09 AM •
GE Ovens
Answered
on Feb 26, 2023
GE Range Model JBP62DM2. Oven and top burners not working.
Even i
f the oven thermal overload sensor is functioning properly, it is less likely to be the cause of the issue with the oven and top burners not working. However, it is still worth checking to ensure that the sensor is not malfunctioning or damaged. The thermal overload sensor is a safety feature that can cause the oven to shut off if it overheats, so if it is faulty or damaged, it could potentially prevent the oven from heating up or cause it to shut off prematurely.
To test the thermal overload sensor, you can use a multimeter to check its resistance. The resistance should increase as the temperature of the oven rises. If the resistance remains the same or is outside the expected range, then the sensor may be faulty and should be replaced. If the sensor appears to be functioning correctly, then you should investigate other potential causes mentioned below,
If the oven and top burners are not working even after replacing the main control board, there could be several other possible causes. Here are a few things to check:
- Check the power supply: Even though the voltage at each input feed wire is 120 volts, the power supply may not be providing enough current to operate the oven and burners. Check the wiring and connections to ensure they are secure and not damaged. You may also want to check the circuit breaker or fuse box to make sure there are no issues with the electrical supply.
- Check the heating elements: The oven and top burners are powered by heating elements. If one or more of the heating elements are faulty, this could be causing the issue. Check the elements for any signs of damage or wear, and test them with a multimeter to ensure they are functioning properly.
- Check the wiring harness: The wiring harness connects the various components of the oven to the control board. If the wiring harness is damaged or has a loose connection, this could be preventing the oven and burners from working. Check the wiring harness to ensure it is securely connected and not damaged.
- Check the safety valve: The safety valve on the oven regulates the flow of gas to the burners. If the safety valve is faulty, it may not be allowing gas to flow to the burners, which could be preventing them from igniting. Check the safety valve to ensure it is functioning correctly.
If you are unable to identify the issue, it may be best to call a qualified technician to diagnose and repair the oven.
2/22/2023 2:02:19 AM •
GE Ovens
Answered
on Feb 22, 2023
I have a GE Dual wave II Microwave System (model # jkp68g0k3). Still works great.
You may be able to find a replacement glass for your GE Dual Wave II microwave system by contacting GE's customer service or parts department. They may have compatible replacement parts available, or be able to direct you to a third-party supplier that carries them. You can also try searching for the part online using the model number of your microwave. However, keep in mind that older models may have limited availability of replacement parts, so you may need to consider alternative solutions such as having the glass custom-cut or purchasing a new microwave.
2/14/2023 6:16:52 AM •
GE Ovens
Answered
on Feb 14, 2023
GE Trivection JT930SOH1 Oven, touch screen not lighting up
The thermal fuse in your GE Trivection JT930SOH1 oven is likely located behind the touch screen control panel. In order to access the thermal fuse, you will likely need to remove the control panel.
Before attempting to access or repair the thermal fuse, it's important to ensure that the oven is unplugged and that you have taken proper safety precautions, such as wearing gloves and eye protection.
Instructions to access the thermal fuse may vary depending on the specific model of your oven, so it's recommended to check the owner's manual for your oven or contact GE for instructions.
However, in general, you may be able to access the thermal fuse by first removing the control knobs and screws that secure the control panel in place. Then, you'll likely be able to lift the control panel off of the oven to access the thermal fuse.
It's important to note that the thermal fuse is a safety device, and it's designed to blow if the oven overheats. If the thermal fuse is blown, it will need to be replaced. If the fuse is not blown and the touch screen is still not lighting up, it could be a problem with the touch screen itself or a problem with the wiring or other electrical components of the oven.
It's recommended to contact a certified technician to diagnose and fix the problem.
1/14/2023 5:15:55 PM •
GE Ovens
Answered
on Jan 14, 2023
