20 Most Recent
Mitsubishi WS-65813 65" Rear Projection HDTV Questions & Answers
Mitsubishi diamond....my tv turns off after only
Beware some technical handyman is necessary for you i think because of high voltage on some parts(inverterboard and mains), It could be some active components on the circuitboard that they can be badly soldered. try with a wooden object to manipulate some components on the circuitboard, a canister coldspray can sometimes also help to search loose or faltering components
SMD components or some bad capacitors, loose supression coils on inverterboards can even be happens.
I have wavy line going across the tv.Sometimes
sounds like a convergence problem. This model is prone to having intermittent convergence, especially when first turned on.
see attached photos and tell me if they look ANYTHING like your lines.
SD TECH
before you rate this information let me know is it anything like photos?
Ws48513
CONVERGENCE PROBLEM..FIND HONEST TV TECH. MAYBE A $300 REPAIR
Have mitsu model # ws-65813 wont turn on
You have a common problem in the DM (Digital Module), more specifically the DM power supply. There are four electrolytic caps in that supply 16v/1000uf that are bad and likely buldged from heat stress. Replacing these caps and the E2P module, a small stand-up board further back on the main DM board should restore normal operation...
You might be lucky enough to have a tech come out and simply replace those caps in-home. It's not a really big job for a qualified tech.
Hope this helps!
Bill
Have a WS65813
Lately the
Hi.
If the picture becomes all distorted after a while, either with colors not matching, or deformed image with bands on sides or up and down of picture, then you need to replace the power amp ICs in the convergence board. This is quite a delicate job and it is done desoldering old ICs and soldering new ones in the convergence board. More components like resistors and capacitors in convergence board may need replacement.The power supply must also be tested, as sometimes a PSU problem may cause a similar effect (if colors are not matching is convergence by the way).
Cost to replace convergence ICs starts at about $200. It can go up to $300/350 if there are further problem. To get a quote and to locate an authorized technician in your area contact
Mitsubishi Support.
Here part list. Most parts are not in stock, but you get parts numbers:
Mitsubishi WS-65813 Parts List.
Regards.
Ginko.
2003 mitsubishi tv model 65813. where is the lamp?
sorry to tell you there is no lamp persay, but a lot of people call the three picture tubes inside the setbulbs but they are not bulbs tell your friends they are wrong!!!!! these are not usually not a end user replaceable as it takes special tools asvwell as tools to replace a picture tubeTechman:>(
Mitsubishi WS-65813
Someone first needs to check the module inside to see if their has been fluid leaking at least get it looked at this is a great tv designed to last alot longer then the new ones
