20 Most Recent
Toshiba e-Studio162 Copier Questions & Answers
Scanner won't work. Can't
try restarting the pc then un insatall it then restart and unplug the machine and wait for the program to prompt for you to switch on the machine hope thathelps you
3/21/2011 5:16:38 PM •
Toshiba...
Answered
on Mar 21, 2011
Computer can't locate my toshiba e-studio 162
Please dont try with setup wizard , please connect the usb cable between computer and printer then turn on the copier at that time new hardware found will appear, then you have to select YES THIS TIME ONLY. you have to select the driver location
5/27/2010 6:20:45 AM •
Toshiba...
Answered
on May 27, 2010
There is a red triangle showing up on the printer
Hi
This normally means the waste tanks are full and it needs to be serviced. The printer will not normally work at all until this is done.
Taking to a computer repair centre as long as they are reputable should resolve the issue (until the next time)
Thanks
Taz
10/23/2009 6:08:41 PM •
Toshiba...
Answered
on Oct 23, 2009
Error code H4-00
Hi:
That error is referring to the fuser unit not reaching it's correct temp. within a specified period of time. You can try clearing this error with the procedure I will give you, but if it comes back then a service tech should look at it.
With the machine on and the error displayed press these keys in this order quickly. # * Clr * This will put you in a service mode. At this point key is 14 and press Start. Shut off the copier and try turning it back on and check to see if the error has gone away.
Andrew
8/9/2009 2:12:41 PM •
Toshiba...
Answered
on Aug 09, 2009
Problem with canon irc3200
hello Josh. I can tell you "bulletproof verbatum" from the service manual what this error code means.But for me to merely try to help you{as I am} , I will be penalized by this website "FIXYA" since unless you are a trained Canon technician the info I provide will not truly "fixya".But I would rather lose my rating than let you potentially be screwed by a the local copier dude.Just please give me a decent rating/vote when you get a chance to comment on thr quality of my help for you. This code has to do with the fusing unit, a common component on all copiers. The fusing unit is responsible for providing extreme heat and pressure to to the paper and potential image as it reaches the exit of the copier. The heat and pressure "bond" the toner to the paper. The temperature can approach 380* F and therefore must be controlled in redundant ways to insure safety. Your machine has among the redundant systems two "active" temperature sensing devices called thermistors.They each monitor the temperature of the "fusing "unit, and are located in different areas to better monitor the temp. They also compare each other's temp to once again insure safety. Your code means that the "non contact" thermistor and the end {contact} thermistor had a difference of temperature readings of 80*c for more than 500 milliseconds.This is abnormal and not possible if all is well. One or both are bad. The code can be reset, but if the problem is genuine and not a fluke then it will return. To reset the code. Press "additional functions" then the 2&8 simaltaneaously, the additional functions again. New screen. Press "function'. Press clear.....ERR. THen ok at the bottom. Power off an dhope for the best.Good luck.
4/14/2009 7:14:13 PM •
Toshiba...
Answered
on Apr 14, 2009
