20 Most Recent
Olympus FE4020 Digital Camera Questions & Answers
I just bought an olympus
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Quikcell 8Gb micro sdhc card
What is your question? If you're asking whether you can use a microSDHC card with this camera, then the answer is yes (with the proper microSDHC-to-SD adapter).
Drivers for fe-4020
You don't need a driver.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as
Picasa.
My Camera (fe4020) doesn't communicate to my
you more detail problem... if just doesn't communicate with, the connectors are mostly problem of the the terminal socket and then main pcb in camera...
I need more detail of your problem...
My camera was drown in swimming pool, then i
Bad news if your camera isn't wheatercamera, the problem you are experiencing at the
moment, is a typical result of a CCD which have blown. A CCD problem would explain the lines on your pictures and the lines on the LCD (since the CCD is used to feed the live image) or simply not image condition.
In order to correct this issue, the repair facility needs to replace the CCD. This is not something you may do on your own, and keep in mind that sometimes the expensive replacement part could better pay for a new camera. Think it!
Hope this helps.
Olympus fe - 4020 lens
I'd definitely take it to a professional at this point-- but odds are you'd be looking at labor costs and parts costs that would exceed the value of the camera.
It keeps turning off
This usually means the batteries are almost dead. If rechargeable types, they can no longer hold a charge. If the batteries are fresh, try another set newly purchased.
I have Olympus FE330 and the Power button stuck in the depressed position and it turns the camera on and off.
First you need to get the button out. But if it is defect (I think it is) that won't help. Did you try to find out what is keeping the button in the depressed position? is it possible there is some dirt around the knob? Something you can remove?I don't think it is worth bringing it to a service center.If they need one hour to repair it will cost twice a new camera of that class.So when you can't get the know out, I think you should start saving up for a new camera.
